Re: Glidden’s Arrow
[Re: Streetwize]
#3192532
11/21/23 11:21 PM
11/21/23 11:21 PM
Posts: 6,136 Melbourne , Australia
LA360
How many RPM are the Aussie Pro Stocks turning?
I've always been fascinated by high RPM motors< I remember the first time I ever saw the tachometer of a turbo F1 car, the sweep started at 4000RPM !!! Mid 10K to a hair over 11K is fairly common. An acquanintance does a few of the GM engines that run currently, he's tested up to about 11400 rpm from memory. Haven't spoken to him in a little while though. The Mopar's don't turn quite as hard, but tended to make the most power of the three. Finding a good block for them is the bigest problem.
Alan Jones
Re: Glidden’s Arrow
[Re: LA360]
#3192688
11/22/23 06:25 PM
11/22/23 06:25 PM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I've always been fascinated by high RPM motors< I remember the first time I ever saw the tachometer of a turbo F1 car, the sweep started at 4000RPM !!! Mid 10K to a hair over 11K is fairly common. An acquanintance does a few of the GM engines that run currently, he's tested up to about 11400 rpm from memory. Haven't spoken to him in a little while though. The Mopar's don't turn quite as hard, but tended to make the most power of the three. Finding a good block for them is the bigest problem. I don't think Ritter makes a block for the P5 heads. I wonder why? Are the lifters locations too different? I understand he does make a block for the P7 heads. Bill
Re: Glidden’s Arrow
[Re: 340Cuda]
#3192691
11/22/23 06:33 PM
11/22/23 06:33 PM
LA360
I've always been fascinated by high RPM motors< I remember the first time I ever saw the tachometer of a turbo F1 car, the sweep started at 4000RPM !!! Mid 10K to a hair over 11K is fairly common. An acquanintance does a few of the GM engines that run currently, he's tested up to about 11400 rpm from memory. Haven't spoken to him in a little while though. The Mopar's don't turn quite as hard, but tended to make the most power of the three. Finding a good block for them is the bigest problem. I don't think Ritter makes a block for the P5 heads. I wonder why? Are the lifters locations too different? I understand he does make a block for the P7 heads. Bill If you sourced a block with a blank lifter valley, you could machine it for a P5 set up. That said, it is far too high in its deck height. Most are running their deck height in the 8.3-8.4" range. If a Mopar block could support even lower, you'd see deck heights at around 8.2" or lower.
Alan Jones
Re: Glidden’s Arrow
[Re: LSP]
#3208291
01/26/24 01:46 PM
01/26/24 01:46 PM
Posts: 1,118 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Recent video dropped to continue the story --> https://www.youtube.com/watch?v=utPDGAEfC14
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Glidden’s Arrow
[Re: Brad_Haak]
#3208305
01/26/24 02:32 PM
01/26/24 02:32 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
I have a bunch of original dyno sheets from a 288 cid small block motor that didn't quite last to 9,000 rpm.
"exhaust lash caps found missing"
It was an idea. But I don’t know if it got raced.
My Chrysler internal correspondence between Tom Hoover, Bob Torozzi, and others seemed to say it was an idea that didn’t work.
Browsing through many runs by Bob Tarozzi’s Phoenix Engineering, looks like all around 520-540 or so peak HP. BTW, SVI= Ted Sphear. DRE = Bud Elkins ported/prepped
This run had rpm “issues” it seems by the comments
