Glove Box Knob
#3191711
11/18/23 01:58 AM
11/18/23 01:58 AM
Posts: 821 On the open road
Hrtbkr
On the open road
Hi I need to remove the glove box knob. I've found a key that fits and rotated it to the versicle position. There's supposed to be a window to access a locking tab-not present on my lock. Are the any suggestions? Thanks
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
Re: Glove Box Knob
[Re: A12]
#3191715
11/18/23 03:42 AM
11/18/23 03:42 AM
Hrtbkr
On the open road
E=Body, not certain what year the lid is from
Re: Glove Box Knob
[Re: PhillyRag]
#3191893
11/18/23 08:34 PM
11/18/23 08:34 PM
Posts: 10,135 A Red State
SNK-EYZ
A Red State
key needs to be inserted to remove or install these
He did.... I've found a key that fits and rotated it to the vertical position.
Re: Glove Box Knob
[Re: SNK-EYZ]
#3192125
11/20/23 12:41 AM
11/20/23 12:41 AM
Posts: 1,755 Phila
PhillyRag
Phila
He did.... I've found a key that fits and rotated it to the vertical position. I know that. Point is: you need the correct key inserted when removing/installing the cylinder from latch.
Re: Glove Box Knob
[Re: PhillyRag]
#3192157
11/20/23 10:28 AM
11/20/23 10:28 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I remove these often using another method. Leave two attaching screws in place. Take flat blade screwdriver and insert into chrome knob slot slightly. Pry to the side and it will pop off. You can then remove the two attaching screws from back side and remove cylinder. To put back together use a socket with tape on end to protect chrome....and press together in your bench vice. Been doing this for years now.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Glove Box Knob
[Re: 70gtx440dana]
#3192562
11/22/23 04:15 AM
11/22/23 04:15 AM
Hrtbkr
On the open road
Having the key and the position of the knob is inconsequential if the window is not there. The image clearly shows where it should be. I took 70gtx440dana's advice (Thank You!) and popped the knob off.
Re: Glove Box Knob
[Re: Hrtbkr]
#3192588
11/22/23 11:40 AM
11/22/23 11:40 AM
70gtx440dana
Lansing, MI
Having the key and the position of the knob is inconsequential if the window is not there. The image clearly shows where it should be. I took 70gtx440dana's advice (Thank You!) and popped the knob off. Your welcome...I remember the frustration of trying to figure this out via photos several years ago. For most i have done..... I have no key. So, this works well.
