Glove Box Knob #3191711
11/18/23 01:58 AM
11/18/23 01:58 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi
I need to remove the glove box knob.
I've found a key that fits and rotated it to the versicle position.
There's supposed to be a window to access a locking tab-not present on my lock.
Are the any suggestions?
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Glove Box Knob [Re: Hrtbkr] #3191714
11/18/23 03:31 AM
11/18/23 03:31 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
What vehicle is this for?
Re: Glove Box Knob [Re: A12] #3191715
11/18/23 03:42 AM
11/18/23 03:42 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
E=Body, not certain what year the lid is from
Re: Glove Box Knob [Re: Hrtbkr] #3191732
11/18/23 09:56 AM
11/18/23 09:56 AM
BDW Offline
BDW  Offline
I think you need to wiggle it a little higher, slot is below that lip
Re: Glove Box Knob [Re: Hrtbkr] #3191883
11/18/23 07:50 PM
11/18/23 07:50 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
key needs to be inserted to remove or install these
Re: Glove Box Knob [Re: PhillyRag] #3191893
11/18/23 08:34 PM
11/18/23 08:34 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
He did....
Quote
I've found a key that fits and rotated it to the vertical position.
Re: Glove Box Knob [Re: SNK-EYZ] #3192125
11/20/23 12:41 AM
11/20/23 12:41 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
He did....
Quote
I know that. Point is: you need the correct key inserted when removing/installing the cylinder from latch.
Re: Glove Box Knob [Re: PhillyRag] #3192157
11/20/23 10:28 AM
11/20/23 10:28 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I remove these often using another method. Leave two attaching screws in place. Take flat blade screwdriver and insert into chrome knob slot slightly. Pry to the side and it will pop off. You can then remove the two attaching screws from back side and remove cylinder. To put back together use a socket with tape on end to protect chrome....and press together in your bench vice. Been doing this for years now.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Glove Box Knob [Re: 70gtx440dana] #3192562
11/22/23 04:15 AM
11/22/23 04:15 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Having the key and the position of the knob is inconsequential if the window is not there.
The image clearly shows where it should be.
I took 70gtx440dana's advice (Thank You!) and popped the knob off.
Re: Glove Box Knob [Re: Hrtbkr] #3192588
11/22/23 11:40 AM
11/22/23 11:40 AM
Lansing, MI
Lansing, MI
Your welcome...I remember the frustration of trying to figure this out via photos several years ago. For most i have done..... I have no key. So, this works well.
