4150/4500 base plate #3190764
11/14/23 08:32 AM
11/14/23 08:32 AM
Mo.
racerx Online work OP
racerx  Online Work OP
Mo.
Billet Aluminum Carburetor 950 Base Plate Holley, Quick Fuel 4150 Dominator 4500
Anyone here ever use one? work How well does it fit the 4500 intake?
Re: 4150/4500 base plate [Re: racerx] #3190785
11/14/23 10:41 AM
11/14/23 10:41 AM
Kentucky
clovis Offline
clovis  Offline
Kentucky
After fighting with transfer slot positions and lengths (especially on older dominators) and based on a couple of recommendations from some carb builders, I am using the BLP dual pattern plate. If you are comparing it to other plates pay extra attention to the transfer slot (width, length and position) in relation to the throttle blades-BLP seems to get this right and it will pay some dividends setting up the carb. It is a nice piece, I use it on my Quick Fuel 950 annular main body. I will say that I have never bolted it to one of my 4500 intakes but I could as the carb is already out and I have a M1 4500 under the bench.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: 4150/4500 base plate [Re: clovis] #3190898
11/14/23 05:45 PM
11/14/23 05:45 PM
Mo.
Mo.
Thanks Clovis ...i was not aware that BLP sold theses base plate ,I'll look into BlP's website and see what they have to offer.
P.S ...sense you have that carb all ready off ,is it possible to set it on the 4500 intake and check alignments....Thanks.
Re: 4150/4500 base plate [Re: racerx] #3191069
11/15/23 11:40 AM
11/15/23 11:40 AM
pa
gregcharger72 Offline
pa
I recently bought a BLP billet duel pattern base plate for my 1000 cfm 4150 carb. It is a high quality product. In comparison to the Holley billet plate I am replacing it matches transfer slot location.
I'm going to run this carb on a trick flow 270 head / max wedge size intake with a 4500 flange. It is not assembled yet so i can't comment on how it runs yet but so far so good.
Re: 4150/4500 base plate [Re: gregcharger72] #3191214
11/15/23 07:27 PM
11/15/23 07:27 PM
Mo.
Mo.
Thanks up
Re: 4150/4500 base plate [Re: racerx] #3191224
11/15/23 07:56 PM
11/15/23 07:56 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
It looks like you may need a spacer. This is a low deck M1 4500, so not sure how close all the 4500 intake patterns would be, but for this one you will either need a spacer that is cut back or do a little grinding on the intake.
'75 Plymouth Duster
Re: 4150/4500 base plate [Re: clovis] #3191315
11/16/23 09:12 AM
11/16/23 09:12 AM
Mo.
Mo.
Thanks for the pictures Clovis upi wondering which 4500 series intake they fit? i have an Indy intake, 4150/4500 adapter anyway just trying to keep it as low as possible. It's only 1 /2" difference. coffee
Re: 4150/4500 base plate [Re: racerx] #3191326
11/16/23 10:41 AM
11/16/23 10:41 AM
NC
440Jim Offline
440Jim  Offline
NC
This is an M1 RB intake with 4500 carb pad. The 4150 carb with dual mounting pattern does need a little grind on the sides to clear the levers as others have shown. I used a 1/2" thick plate with cutout/reliefs to clear the carbs 50cc accelerator pumps.
Re: 4150/4500 base plate [Re: 440Jim] #3191350
11/16/23 12:56 PM
11/16/23 12:56 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Now, that I think about it, I have an Indy 440-3 on my race engine, so I'll try to snap a few pictures tonight to see what kind of clearance issues are there.
'75 Plymouth Duster
Re: 4150/4500 base plate [Re: clovis] #3191370
11/16/23 02:15 PM
11/16/23 02:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We make an adapter for using a 4150 on a 4500 intake...Basically just to make a transition from the large plenum opening on a 4500 to the smaller 4150 and also adress the accel pump and linkage. I have a Bob Book 4150 that has both patterns in it on the 64.
Re: 4150/4500 base plate [Re: Al_Alguire] #3191466
11/16/23 09:08 PM
11/16/23 09:08 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I have made a few "adapter" spacers forthis kind of swap. They have always worked well.
Alan Jones
Re: 4150/4500 base plate [Re: LA360] #3191487
11/16/23 09:44 PM
11/16/23 09:44 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
It seems to work on the 440-3. The intake is cut back a little on sides which give it the clearance it needs to sit flat.
'75 Plymouth Duster
Re: 4150/4500 base plate [Re: clovis] #3191549
11/17/23 08:45 AM
11/17/23 08:45 AM
Mo.
Mo.
Thanks Clovis for the pictures: up: I run the 400-3 intake, so there shouldn't be a clearance issue. Did you check for full throttle motion for clearance?
Re: 4150/4500 base plate [Re: racerx] #3191552
11/17/23 09:10 AM
11/17/23 09:10 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Can you do it, yes in any number of ways. There was a time (maybe still is?) where certain class rules outlawed dual pattern baseplates. Just keep that in mind because being able to run your car in many classes is good. The other concern that I'll air is; sell the 4150 and put a 4500 on it.
Re: 4150/4500 base plate [Re: HardcoreB] #3191592
11/17/23 12:55 PM
11/17/23 12:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The 4150 on mine was for some NSS class. But I am done fighting it and will be selling off me Book 4150. Worked ok for my deal but the Braswell 4500 that replaced it was almost .2 quicker on my junk...
Re: 4150/4500 base plate [Re: HardcoreB] #3191629
11/17/23 03:52 PM
11/17/23 03:52 PM
Mo.
Mo.
Well i looking at using what i have ,also this is for a blow though setup.
Re: 4150/4500 base plate [Re: Al_Alguire] #3191631
11/17/23 04:18 PM
11/17/23 04:18 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Sorry, I didn't check full throttle. The engine is sitting in a corner taped up so I was too lazy to take the tape off the intake. I'll either go down this afternoon or tomorrow for you.
'75 Plymouth Duster
Re: 4150/4500 base plate [Re: clovis] #3191920
11/18/23 11:49 PM
11/18/23 11:49 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
The linkage will clear.
'75 Plymouth Duster
Re: 4150/4500 base plate [Re: clovis] #3191924
11/19/23 01:15 AM
11/19/23 01:15 AM
Mo.
Mo.
Thanks, Clovis You have been helpful up
Re: 4150/4500 base plate [Re: racerx] #3192028
11/19/23 02:14 PM
11/19/23 02:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It doesn’t appear to be available any longer, but Quick Fuel sold a spacer to remedy the fit/interference issues.
https://www.holley.com/products/discontinued_product/parts/300-4145-1ALQFT
