2003 Ram 1500 Headlight prob. #3189223
11/06/23 10:09 PM
11/06/23 10:09 PM
sc
tjmarcus1 Offline OP
sc
[b][/b] Right side headlight doesn't have power on low or high beam. I've checked all I know to check. HELP!
Re: 2003 Ram 1500 Headlight prob. [Re: tjmarcus1] #3189234
11/06/23 11:12 PM
11/06/23 11:12 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Did you test the fuses? Not just look and say they were ok. Actually test them?
Re: 2003 Ram 1500 Headlight prob. [Re: NITROUSN] #3189236
11/06/23 11:48 PM
11/06/23 11:48 PM
sc
sc
[b][/b] Yes I tested them with a test light.
Re: 2003 Ram 1500 Headlight prob. [Re: tjmarcus1] #3189290
11/07/23 10:10 AM
11/07/23 10:10 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I know this sounds hokey, but try it.
Switch your high/low beam selector about 20 times and recheck for power. It only takes a minute, and worth a try.
Re: 2003 Ram 1500 Headlight prob. [Re: Fat_Mike] #3189311
11/07/23 11:32 AM
11/07/23 11:32 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: 2003 Ram 1500 Headlight prob. [Re: mopars4ever] #3189549
11/08/23 02:54 AM
11/08/23 02:54 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Originally Posted by mopars4ever
This...
It's what's usually wrong on that era Rams headlights when there are problems.
I never understood why they felt the need to have what's essentially a computer board control the headlights.
A simple fuse and a switch wasn't good enough anymore. shruggy
When I parted several 2003 & 2004 Rams there was always a buyer for the FCM because of the headlight issue.
Re: 2003 Ram 1500 Headlight prob. [Re: SNK-EYZ] #3190492
11/12/23 05:32 PM
11/12/23 05:32 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
I agree fuse box issue,changed quiet a few for headlight problem.
Re: 2003 Ram 1500 Headlight prob. [Re: GarageDodge] #3190519
11/12/23 07:52 PM
11/12/23 07:52 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
So my question is, could a guy just connect the posts coming into the module with the posts that power the head lights and eliminate the module?
At some point, the used good modules are going to be non-existent, and the new ones might be gone from the market as well, the trucks are already 20 years old, or very near 20 years old.
I don't see why you couldn't go directly from the fuse to the headlight lights and eliminate the module and the printed board before it. What am I missing?
