Upper control arm installation #3189360
11/07/23 01:54 PM
11/07/23 01:54 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I'm in the process of installing the front suspension on my 69 Dart including later model A-body disk brakes. When installing the upper control arms, is there a recommended way the bolts/cams should be positioned? Any other tips on the suspension install would be appreciated as well as this is the first time I've ever done it.
Re: Upper control arm installation [Re: 6PAX] #3189401
11/07/23 03:53 PM
11/07/23 03:53 PM
I would look at the factory service manual procedures and go from there scope up wrench twocents
Re: Upper control arm installation [Re: 6PAX] #3189410
11/07/23 04:16 PM
11/07/23 04:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The bolts should be installed with the nuts in the engine compartment.
Re: Upper control arm installation [Re: John_Kunkel] #3189542
11/08/23 01:26 AM
11/08/23 01:26 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
How could that be done when the mounting points are outboard of the inner fenders and not in the engine compartment?
Re: Upper control arm installation [Re: kentj340] #3189565
11/08/23 08:08 AM
11/08/23 08:08 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Bolts always go in from the center pointing outwards on any Mopar. During an alignment the nuts are extremely difficult to tighten with the tires installed if they are towards the shock.
Doug
Re: Upper control arm installation [Re: kentj340] #3189621
11/08/23 01:33 PM
11/08/23 01:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
OOPS, was thinking of B-bodies.
