Re: Aluminum Block prep.
[Re: racerx]
#3189266
11/07/23 09:02 AM
11/07/23 09:02 AM
Posts: 4,070 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Are you all removing casting flash on these block? What else is being done before machining? Is there a particular block you are asking about? Depending on the era and maker some were reported as wash and assemble after a final hone of course.
[Re: racerx]
#3189278
11/07/23 09:33 AM
11/07/23 09:33 AM
Posts: 2,926 A shed in England
Tig
A shed in England
The KB block we got in 2009 was almost ready to go as delivered, washed down, oil galleys flushed out, dried and assembled. As cast it was of a very good quality.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3189331
11/07/23 12:34 PM
11/07/23 12:34 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
The KB block we got in 2009 was almost ready to go as delivered, washed down, oil galleys flushed out, dried and assembled. As cast it was of a very good quality. Got mine in 2006.
[Re: an8sec70cuda]
#3189345
11/07/23 01:23 PM
11/07/23 01:23 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
Agreed on the KB blocks. I have 2 of them.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3189379
11/07/23 02:51 PM
11/07/23 02:51 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
I have all of them and these days final hone and wash is about all thats needed.
[Re: HardcoreB]
#3189509
11/07/23 09:52 PM
11/07/23 09:52 PM
Posts: 4,072 Mo.
racerx
Mo.
Are you all removing casting flash on these block? What else is being done before machining? Is there a particular block you are asking about? Depending on the era and maker some were reported as wash and assemble after a final hone of course. It's a indy maxx
[Re: racerx]
#3190361
11/12/23 01:28 AM
11/12/23 01:28 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
If anything, i believe you will be ahead of the game to thoroughly check and clean any aftermarket block just as we do to a stock block. It is preventing any chances of contamination….i guarantee that I can find some grit, shavings, etc in any block if thoroughly checked. There are just too many spots/ crevices for something to remain. I found some very small amounts of material in an Indy maxx block a few years ago and will check a mega block from ‘06 just as thoroughly when the time comes.
[Re: racerx]
#3190768
11/14/23 08:49 AM
11/14/23 08:49 AM
Tig
A shed in England
The INdy is not date stamped but they do have serial numbers that you can call Indy to get more info. Or just send me an email and I will get you a copy of the original order. On the indy blocks, take a boroscope or bright light and go up the main oil feed holes to where it intersects the main galley. Make sure that intersection is fully drilled and free of slag and crud. I also enlarge the oil drain holes on the top of the cam tunnel about double what they come at. I also drill a small hole in the China wall in the front of the block to allow oil to go down the front of the block. Other wise all it gets is splashed off the crank up there. Important for gear drives and timing chains both. Wash, wash and wash it again......Todd Thanks Todd can you explain a little more on the china wall I'm pretty sure this is what Todd was referring to, #1 and #2 lifter galley pictured. Todd built our 655. Apologies for butting in here Todd.
[Re: sasquatch]
#3190772
11/14/23 09:04 AM
11/14/23 09:04 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I have a motor I bought that’s an Indy block. I would like to get the info on. Where is the serial # on Indy blocks?I would love to find who originally bought/ built this motor
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: 65 Hemi]
#3190797
11/14/23 11:38 AM
11/14/23 11:38 AM
Posts: 10,038 MN
JERICOGTX
MN
I have a motor I bought that’s an Indy block. I would like to get the info on. Where is the serial # on Indy blocks?I would love to find who originally bought/ built this motor In the rear, by the transmission mating flange.
69 GTX
68 Road Runner
