904 - 3rd Gear Apply - Slow #318873
05/15/09 12:14 PM
05/15/09 12:14 PM
Motor City
Shaker223 Offline OP
Motor City
I have a 904 with a Turbo Action low gear apply manual valve body. Nothing special on the rebuild, 3.8 lever, 5 clutch drum, accumulator blocked.
Trans shifts fine but there is a lag between the 2-3 shift where you can hear the engine increase slightly in speed between the 2-3 shift.
What can I do to apply 3rd faster?
Please let me know if you need additional info.
Thanks.
Re: 904 - 3rd Gear Apply - Slow [Re: Shaker223] #318874
05/15/09 12:52 PM
05/15/09 12:52 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
does the case have a restricter in it for 3rd gear clutch a lot of shift kits use this restricter the manual vb does not need it.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 904 - 3rd Gear Apply - Slow [Re: dusturbd340W5] #318875
05/15/09 01:01 PM
05/15/09 01:01 PM
Motor City
Motor City
Good call, it might have one. I put this togeter over a year ago and it did have a trans go kit in it before. looks like I need to check that because I cannot remember.
Re: 904 - 3rd Gear Apply - Slow [Re: Shaker223] #318876
05/15/09 02:46 PM
05/15/09 02:46 PM
Motor City
Motor City
Just pulled pan and VB. No plug, I did take it out.
Re: 904 - 3rd Gear Apply - Slow [Re: Shaker223] #318877
05/15/09 03:09 PM
05/15/09 03:09 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
With the VB out you might want to air test the front clutch. Leakage at the rings/seals will make the clutch slow to apply.
Re: 904 - 3rd Gear Apply - Slow [Re: John_Kunkel] #318878
05/15/09 03:17 PM
05/15/09 03:17 PM
Motor City
Motor City
I can do that but what should I watch for and how would I know there is leakage?
Re: 904 - 3rd Gear Apply - Slow [Re: Shaker223] #318879
05/16/09 03:18 PM
05/16/09 03:18 PM
Rio Linda, CA
Rio Linda, CA
Use a rubber-tipped blow gun in the front clutch port in the case, when you hit it with air you should hear the "thump" as the piston applies and minimal air leakage kinda like bacon sizzling. Any sound of blowing air isn't good.
Re: 904 - 3rd Gear Apply - Slow [Re: John_Kunkel] #318880
05/16/09 08:39 PM
05/16/09 08:39 PM
Motor City
Motor City
Thanks. I'll check.
Re: 904 - 3rd Gear Apply - Slow [Re: Shaker223] #318881
05/16/09 08:45 PM
05/16/09 08:45 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
ADD some ATF into that port to get a clearier and more precise "sound".
Re: 904 - 3rd Gear Apply - Slow [Re: Shaker223] #318882
05/16/09 09:09 PM
05/16/09 09:09 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
If the kick-down band (front) is too loose it will allow a
flair on the 2-3 shift. Just a thought.
