Re: 904 - 3rd Gear Apply - Slow
[Re: Shaker223]
#318874
05/15/09 12:52 PM
05/15/09 12:52 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
does the case have a restricter in it for 3rd gear clutch a lot of shift kits use this restricter the manual vb does not need it.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#318875
05/15/09 01:01 PM
05/15/09 01:01 PM
Posts: 365 Motor City
Shaker223
Motor City
Good call, it might have one. I put this togeter over a year ago and it did have a trans go kit in it before. looks like I need to check that because I cannot remember.
[Re: Shaker223]
#318877
05/15/09 03:09 PM
05/15/09 03:09 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
With the VB out you might want to air test the front clutch. Leakage at the rings/seals will make the clutch slow to apply.
[Re: Shaker223]
#318879
05/16/09 03:18 PM
05/16/09 03:18 PM
John_Kunkel
Rio Linda, CA
Use a rubber-tipped blow gun in the front clutch port in the case, when you hit it with air you should hear the "thump" as the piston applies and minimal air leakage kinda like bacon sizzling. Any sound of blowing air isn't good.
