Rebuilding Roller Lifters
#3188308
11/02/23 04:24 PM
11/02/23 04:24 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
I am looking to see if any of the companies out there will rebuild roller lifters. I have run the Comp Endure X 829-16 roller lifters in my stuff for a long time. Have never had an issue. For years I had two sets on rotation. I would remove them after 300 - 350 runs and then replace them. Once I took them out I would send them back to Comp and they would go through them. So I always had a relatively fresh set in the motor with a rebuilt set on hand.
However, Comp is no longer offering this service and it is difficult to find other lifters that have the same cup height. I could replace them but then I am buying new push rods again.
If anyone knows of a place I have three sets that I would send back at this point.
Thanks in advance.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
Re: Rebuilding Roller Lifters
[Re: LA360]
#3188385
11/02/23 11:15 PM
11/02/23 11:15 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
My unsolicited opinion is, toss them and go with something higher quality.
[Re: INTMD8]
#3188397
11/03/23 01:24 AM
11/03/23 01:24 AM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
Following. I've got a set of Comps ready for a rebuild as well.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: jwb123]
#3188441
11/03/23 10:18 AM
11/03/23 10:18 AM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought some comp lifters a few years ago just because of the ability to rebuild, and the fact that comp said they would rebuild them. I freshened the engine and called comp they said they had discontinued the rebuilding service. So I just bought another brand screw them. You probably bought a set from one of the companies comp is now in with. Lol 😂
[Re: pittsburghracer]
#3188972
11/05/23 06:46 PM
11/05/23 06:46 PM
Posts: 6,136 Melbourne , Australia
LA360
Unless spare parts are available, you're going to have to switch brands sadly. BAM, Isky and Jesel are rebuildable. I am sure there are others
Alan Jones
[Re: dvw]
#3189362
11/07/23 02:07 PM
11/07/23 02:07 PM
Posts: 2,497 PA
moparacer
PA
1.79 is the height on the 829s. I guess I am in the same boat with my lifters. I bought the bushed 829B sportsmans several years ago and planned on having them rebuilt and here we are..... They are freaking $1200 now too. I have over 600 passes on them at 800lb spring pressure so I can vouch for them as far as quality, but not being able to have them rebuilt now sucks.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3189869
11/09/23 03:29 PM
11/09/23 03:29 PM
451Guy
Alberta, Canada
Thanks everyone for the responses.
It is frustrating when you purchase a product with an expectation of a service moving forward and things change.
I will looking the other options and see what I can come up with. However, I will only purchase from a company that offers rebuilding down the road.
Thanx 451 Guy
[Re: 451Guy]
#3189987
11/10/23 05:08 AM
11/10/23 05:08 AM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
Apparently the 511 in my gts is getting a set of Isky red zones when it is time to rebuild the $1000+ bushed Comp Sportman lifters. What a bunch of punks!
