Timing set for raised cam Hemi? #3188045
11/01/23 01:46 PM
11/01/23 01:46 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Other than a belt, what are the available options for a timing set on a raised cam KB block block?
I know that big block Chevy's have the same cam to crank center line as a big block Mopar. Is there a bbc raised cam timing chain that could be used with Hemi sprockets? Is a gear drive available?
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Timing set for raised cam Hemi? [Re: Hemi_Joel] #3188068
11/01/23 03:12 PM
11/01/23 03:12 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Milodon gear drive 13001. 0.250 raised cam.
Re: Timing set for raised cam Hemi? [Re: rickraw] #3188108
11/01/23 06:19 PM
11/01/23 06:19 PM
Minnesota
Minnesota
Thanks Rick!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Timing set for raised cam Hemi? [Re: Hemi_Joel] #3188121
11/01/23 06:58 PM
11/01/23 06:58 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Plenty of gear drives available...not so sure about a chain.sprocket set up though..
Id try Wizards first.. This is where I do most my gett'n stuff at. Tell'em Bill in NY sent you!
RBS sells them Too
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Timing set for raised cam Hemi? [Re: Hemi_Joel] #3188122
11/01/23 06:58 PM
11/01/23 06:58 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
RCD (and others) also make them. Donovan may have one for raised cam.
2011 Drag Pak Challenger
Re: Timing set for raised cam Hemi? [Re: rickseeman] #3188260
11/02/23 12:32 PM
11/02/23 12:32 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Have always had good luck with RCD even with BBC stuff.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Timing set for raised cam Hemi? [Re: 6PKRTSE] #3188266
11/02/23 12:49 PM
11/02/23 12:49 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Did you order a block Joel?
69 GTX 68 Road Runner
Re: Timing set for raised cam Hemi? [Re: JERICOGTX] #3188321
11/02/23 05:33 PM
11/02/23 05:33 PM
Minnesota
Minnesota
No, I'm still on the fence.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Timing set for raised cam Hemi? [Re: Hemi_Joel] #3188420
11/03/23 08:22 AM
11/03/23 08:22 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Do I see a 5" crank in you future?????
Re: Timing set for raised cam Hemi? [Re: quickd100] #3188646
11/03/23 11:19 PM
11/03/23 11:19 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I believe using the belt that this gets rid of all the bad harmonics throught the Chain and Sprockets. I believe the belt is a common thing in performance motors, but the price years ago with the raised block was not that cheap. I would phone Banning or Barton and talk to them on what other timing Chain, Drive they recommend.
1971 HEMI E BODY REGISTRY
Re: Timing set for raised cam Hemi? [Re: hemicar1971] #3188838
11/05/23 02:01 AM
11/05/23 02:01 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Joel
Just thinking out loud here. I wonder if the Indy timing cover would cover the belt drive. Ati makes the damper for it. Full disclosure Joel and I have been discussing this. His concern with a belt drive is he wants to do Drag week and Belt drives can pick up all sorts of things flying down the open road. I pulled a large stone out of one the other day! So maybe we could cover it up.......Let me look into this.
Todd
Re: Timing set for raised cam Hemi? [Re: sasquatch] #3188874
11/05/23 11:06 AM
11/05/23 11:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I am sure you could even make a stock stlye cover fit, might take a spacer if sorts but why not.
Re: Timing set for raised cam Hemi? [Re: hemicar1971] #3188904
11/05/23 12:34 PM
11/05/23 12:34 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
They are worse now. Over $2,000 including tax. I've bought hemicudas cheaper.
Re: Timing set for raised cam Hemi? [Re: sasquatch] #3189058
11/06/23 06:58 AM
11/06/23 06:58 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted by sasquatch
Joel
Todd
The odds of it happening are very slim... Plenty of people running belts on Drag and Drive events without issues. I do have a INDY cover if Joel wants to look at it. NO Joel, you can't use it... LOL.
Re: Timing set for raised cam Hemi? [Re: Al_Alguire] #3189104
11/06/23 01:35 PM
11/06/23 01:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I started to cobble up a stock timing cover to put over a jesel years ago , never finished it and ended up selling the jesel. I started by cutting the bottom flange off , left out the balancer seal.
Re: Timing set for raised cam Hemi? [Re: JohnRR] #3189149
11/06/23 04:10 PM
11/06/23 04:10 PM
Minnesota
Minnesota
I suppose anything is possible...
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Timing set for raised cam Hemi? [Re: Hemi_Joel] #3189177
11/06/23 06:06 PM
11/06/23 06:06 PM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
Someone makes covers for Jesel belt drives for SBC that run in dirt track cars and mud bog trucks. Can't remember who, but I don't think that it is Jesel. (could be wrong though) Not sure if they are made for anything else. They are two piece, (upper and lower) made out of thin sheet metal and just bolt over top of Jesel unit, not really tight to the balancer hub. I actually just took one off of an old NASCAR engine that was converted to a drag race engine, and give it back to the customer.
Brian
Re: Timing set for raised cam Hemi? [Re: '72CudaRacer] #3189972
11/09/23 11:15 PM
11/09/23 11:15 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Have not talked to Banning about this for a long while but the old research for using a Chain and Sprockets states that there are none and likely will never be any for this raise came block, unless someone does a lot of research into building one. Talked to a couple of racers that have the belts and have no problem with them. Was told that Oil is a killer of the belts. These belt assemblies are not cheap but do add some benifits to the motors.
Re: Timing set for raised cam Hemi? [Re: hemicar1971] #3190029
11/10/23 11:55 AM
11/10/23 11:55 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Banning has a raised cam belt drive listed on his website. I assume it's the one made by the Aussies. Just speculation.
Re: Timing set for raised cam Hemi? [Re: rickseeman] #3190030
11/10/23 11:57 AM
11/10/23 11:57 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
If you buy a belt drive after 10 years you will have spent more on belts than a gear drive costs.
