Took the Charger to the track today. #3187067
10/28/23 02:46 PM
10/28/23 02:46 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
I decided to drive up to Great Lakes Dragaway this morning and make a few passes. The car is 4,100lbs and 4,270 with me in it.
Ran it as it always is, through full exhaust and on the road race tires. (just saying I didn't drop the exhaust or have it on drag wheels)
First run I slipped the clutch out at 4,200 rpm and it actually hooked but absolutely obliterated the clutch. It was slipping down the entire track and flaring on the shifts.
I let it have a good cool down and tried dumping the clutch at 3200 but it just spun. I still pedaled it and ran it out.
Shifted it normally (with clutch and lifting throttle) at 7,650rpm. Trans is a TKO600, 4.56 rear gear.
The clutch is a McLeod rst, so dual disc organic. Seems like I would need a rxt (miba lining discs) and/or more pressure plate to really launch it well.
It ran perfect at least. It has a tanks inc tank but I added some baffling to the bucket. Rock solid fuel pressure through the entire pass.
Re: Took the Charger to the track today. [Re: INTMD8] #3187074
10/28/23 02:58 PM
10/28/23 02:58 PM
moparx Offline
moparx  Offline
i REALLY like your car ! up bow
beer
Re: Took the Charger to the track today. [Re: INTMD8] #3187097
10/28/23 03:46 PM
10/28/23 03:46 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice speed!!
Pretty good 60’ slipping the clutch.
Re: Took the Charger to the track today. [Re: INTMD8] #3187109
10/28/23 04:50 PM
10/28/23 04:50 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Awesome, your tank is the updated version also with the transfer tubes ???? glad you made it to the track !!!!!! Looks like you had great DA, BUT I see you had a 16 ish MPH direct headwind
Re: Took the Charger to the track today. [Re: INTMD8] #3187141
10/28/23 06:32 PM
10/28/23 06:32 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That thing is making some steam! Killer day to be at the track as well. Do you think it picked up any mph from your incredible airbox mod?
Re: Took the Charger to the track today. [Re: Blusmbl] #3187147
10/28/23 06:50 PM
10/28/23 06:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
29 mph gain in the back half. Pretty good power.
Doug
Re: Took the Charger to the track today. [Re: INTMD8] #3187189
10/28/23 09:16 PM
10/28/23 09:16 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Sounds like a great time, I bet the car is alot of fun to drive.
Definitely one of my favorites on the board. I have not always been logged in while reading and didn't comment, but have sincerely enjoyed your posts about everything you've done with it.
Rich H.
Esse Quam Videri
Re: Took the Charger to the track today. [Re: ZIPPY] #3187227
10/29/23 12:04 AM
10/29/23 12:04 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thanks guys. It's no race car but thought I would share the results.
Not sure what the air cleaner was worth but it brought the intake air temps from 50-60 above ambient to 15-20 over ambient. I think it could do better with a hood scoop and not a drop base assembly but that's not the look I'm going for on this one.
CSK yes it is the newer version with the transfer tubes. Not trying to say it's great or anything because I think it certainly isn't out of the box, just that it's working ok with additional baffling.
Re: Took the Charger to the track today. [Re: INTMD8] #3187257
10/29/23 07:46 AM
10/29/23 07:46 AM
E
earlymopar Offline
earlymopar  Offline
E
Beautiful and very nice running car. Your numbers are especially good considering the car's weight and the tires you were running on! I wanted to confirm you were actually shifting at 7,650 rpm? I have the same transmission and rear end ratio so am curious how the shifting went, especially if the RPM you mentioned is correct.
Re: Took the Charger to the track today. [Re: earlymopar] #3187343
10/29/23 01:18 PM
10/29/23 01:18 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thank you. I looked at the log and it was actually 7,750. It shifted great, I had no trouble with that. I did have the trans apart to change the overdrive ratio to .82 and it just had regular brass synchros.
Re: Took the Charger to the track today. [Re: INTMD8] #3187405
10/29/23 03:38 PM
10/29/23 03:38 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Nice work! Very impressive for sure, and a beautiful, beautiful…….BEAUTIFUL, Charger!
"Any fool can know. The point is to understand"
- A. Einstein
Re: Took the Charger to the track today. [Re: EvilB1Dart] #3187630
10/30/23 01:05 PM
10/30/23 01:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Awesome car for sure.
Re: Took the Charger to the track today. [Re: Al_Alguire] #3187638
10/30/23 01:36 PM
10/30/23 01:36 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thanks guys, I appreciate it.
Re: Took the Charger to the track today. [Re: INTMD8] #3187786
10/31/23 08:05 AM
10/31/23 08:05 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Excellent update, thanks for sharing! Now let's all pick out a hoodscoop for that thing!?
Re: Took the Charger to the track today. [Re: HardcoreB] #3187926
10/31/23 08:27 PM
10/31/23 08:27 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That is a super cool beautiful car. Was the high RPM an accident or is the engine built to run up there?
Re: Took the Charger to the track today. [Re: ProSport] #3187952
10/31/23 10:36 PM
10/31/23 10:36 PM
BigFish69 Offline
BigFish69  Offline
Great looking car love the wheels
Re: Took the Charger to the track today. [Re: BigFish69] #3187963
11/01/23 12:23 AM
11/01/23 12:23 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
HardcoreB- slippery slope! Then we have to pick out a tunnel ram.
Prosport- I know it seems kind of weird being a heavy street car but I wanted to build a higher rpm engine and run short gearing. I think it's a lot of fun. That's why I kept the 3.75 crank.
I had an idea of how I wanted to get there but I was using performance trends engine analyzer as well.
It was calculating peak hp at 7000-7500 and I thought maybe it wouldn't quite get there with an air cleaner and full exhaust but it did, making peak power at 7200-7500.
So it could probably use a higher shift point than 7750 but I don't think I want to push my luck with steel valves . (though I did pay a lot of attention to weight on the valve side in terms of valve weight, small diameter valve springs and Ti locks/retainers)
BigFish69- Thanks!
Re: Took the Charger to the track today. [Re: INTMD8] #3187990
11/01/23 09:01 AM
11/01/23 09:01 AM
an8sec70cuda Offline
None of the pics show up for me, so I have no clue what the car looks like (other than your avatar) or what it ran...but from what I've read, it's cool!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Took the Charger to the track today. [Re: an8sec70cuda] #3188012
11/01/23 11:01 AM
11/01/23 11:01 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Awesome Charger and very unassuming! And making some serious steam there. Good day a Da Grove. Looks like you could've made 42 passes if you wanted.
2 kids and a dog
