Permatex gasket maker selection chart #3186918
10/27/23 08:13 PM
10/27/23 08:13 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
In case you were wondering. I know I have needed this chart before. First time I have seen it.
https://permatextraining.com/wp-content/uploads/2021/12/20507-Permatex-Gasket-Selector-Chart-2-1.pdf
Master, again and still
Re: Permatex gasket maker selection chart [Re: DaveRS23] #3186920
10/27/23 08:17 PM
10/27/23 08:17 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Good info to have up
BTW... whoever gave you that title under your name.... shake_head
Plymouth Makes It!
Re: Permatex gasket maker selection chart [Re: RoadRunnerLuva] #3186923
10/27/23 08:49 PM
10/27/23 08:49 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
That chart helps a lot. Downloaded and saved it.
I keep telling friends and relatives who work on their own stuff that they make specific sealers for what your working on, and yet they keep buying the same one size fits all black or blue stuff over and over. Then they cry when their thermostat housing or transmission pan starts leaking again. Hello! It's not made to go up against those types of fluids. They don't want to buy the specific ones as they can't be used on everything is likely what the deal is.
Re: Permatex gasket maker selection chart [Re: DaveRS23] #3186929
10/27/23 09:25 PM
10/27/23 09:25 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Thanks for Posting up
Re: Permatex gasket maker selection chart [Re: Neil] #3186932
10/27/23 09:37 PM
10/27/23 09:37 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Not disagreeing with you in any way but looking atthe chart, which sealer is one supposed to use when oil and anitfreeze are present. Think SB (as well as many others) Timing cover, Intake coolant passages etc.
Only ones I see that might work per the chart is the 90 or One minute sealers shruggy beer
Re: Permatex gasket maker selection chart [Re: TJP] #3186937
10/27/23 09:56 PM
10/27/23 09:56 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Very helpful… thanks.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Permatex gasket maker selection chart [Re: BloFish] #3186952
10/27/23 10:46 PM
10/27/23 10:46 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm surprised they didn't include this.
Automatic Transmission RTV
Re: Permatex gasket maker selection chart [Re: 6PakBee] #3186966
10/28/23 02:59 AM
10/28/23 02:59 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
The Copper for exhaust is not listed either
Re: Permatex gasket maker selection chart [Re: DaveRS23] #3186970
10/28/23 06:19 AM
10/28/23 06:19 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Thank you.
I did not know that there are now
3 different formulations of “The Right Stuff” cheese whiz
Only the red squeeze tube, delayed set, high temperature goes up to 750 degrees F
Re: Permatex gasket maker selection chart [Re: TJP] #3187027
10/28/23 01:18 PM
10/28/23 01:18 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
They grey one on the very far left is for exposure to antifreeze. They also sell it in smaller tubes that are sized just right to do those types of 1 time jobs. I've used it and it does work. They also have one for differential gear oil that is great also.
Re: Permatex gasket maker selection chart [Re: Neil] #3187036
10/28/23 01:46 PM
10/28/23 01:46 PM
moparx Offline
moparx  Offline
thanks for posting that chart ! really appreciate it. up bow
beer
