Re: gen 2 hemi A body mods
[Re: mopar dave]
#3185851
10/23/23 09:38 AM
10/23/23 09:38 AM
Posts: 12,537 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
![[Linked Image]](https://i.postimg.cc/2jMq97Dr/2019-01-12-19-42-32.jpg) I just cut into the pass side inner fender and installed a piece of angle iron. It looked good and allowed the removal of the VC. Wasn't that much work for the body shop. And I used stainless flex lines from the master so that it was easier to lay aside. ![[Linked Image]](https://i.postimg.cc/qvW5DY74/2019-01-12-16-17-16.jpg) And I kept the torsion bars, too. Had to have several tubes custom made in the headers to fit.
Master, again and still
[Re: mopar dave]
#3185882
10/23/23 11:23 AM
10/23/23 11:23 AM
Posts: 75,194 A Banana Republic near you.
JohnRR
Would appreciate if anyone with pics of the mods could post them. Mainly concerned with the inner fender pass side mod. Still not certain on what oil pan and headers to use on this. Will be mostly street driver. Headers are available , the factory I think just used the 66-69 pan as it has the idler arm notch? If you are going to change the K you should should be able to get the 70 up 6pk/hemi pan in with any mods , but you'll probably want some sort of skid plate ?
[Re: rickseeman]
#3185887
10/23/23 11:38 AM
10/23/23 11:38 AM
Posts: 2,303 NE Ohio
DoubleD
NE Ohio
I think this is what you need And a couple of cases of beer and a box of Band-Aids!
[Re: rickseeman]
#3185888
10/23/23 11:43 AM
10/23/23 11:43 AM
Posts: 2,695 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
As you know there is an offset mount for the brake master cylinder that has been selling for the last 50 years as used on the 68 cars. My buddy recently did a Dart and found a new mount that takes it further over. You will want that. MR2 Performance 765-483-9311. He can take the valve cover off without touching the brake lines. Hemi's in A bodies are tight. I'm sure the aftermarket K-members would make it easier but they b pricy.
2011 Drag Pak Challenger
[Re: mopar dave]
#3185893
10/23/23 11:59 AM
10/23/23 11:59 AM
rickseeman
Stuttgart, Arkansas
Would appreciate if anyone with pics of the mods could post them. Mainly concerned with the inner fender pass side mod. Still not certain on what oil pan and headers to use on this. Will be mostly street driver. The headers have to be perfect to wrap around that steering box. He used the Hooker Super Comps but still there was a hammer involved. I think he has another used set of those that he would sell. Another friend put a 400 in a 68 Barracuda recently. We used the 7 qt pan from 440 Source 121-1030. It fit tight, but it fit. (We probably should have trimmed on that lip of the lower K-member before we tried to put it in.) Here's a pix of that offset brake bracket.
[Re: rickseeman]
#3185956
10/23/23 03:17 PM
10/23/23 03:17 PM
Posts: 20,263 Park Forest, IL
slantzilla
Park Forest, IL
I think this is what you need I was considering doing a Hemi A-body years ago. I talked to some of the AH guys at Indy with original cars about the fenderwell modification. Most of them told me that they used a sledge hammer when they were built, and some got bondo to pretty them up and some didn't. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: mopar dave]
#3186029
10/23/23 07:57 PM
10/23/23 07:57 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Thank you. Just what im looking for. Another gentleman told me it doesnt even need much clearancing, just a slit cut, hammer in and dress it up to look clean. Do you have another pic of the pass side with engine in? Nice work by the way. I looked for more pics of that area and haven't come up with any. Thank you for the complement, but it was the body shop that did the work. I just trial fitted the angle iron and cut enough to get the right clearance. It wasn't that much time for them to slick it up. What master cylinder are you contemplating? I just used the late model O.E. Mopar one with the 4 bolt to 2 bolt adapter. Two nuts on the master along with the flex lines and the master was off and completely out of the way in like 2 minutes. Makes getting to the rear rockers on that side easier, too. Working around any master cylinder to adjust those rear rockers can require some gymnastics. And it is all cheap to boot.
