Re: School me on spark plug wires
[Re: 68shifter]
#3185004
10/19/23 10:51 AM
10/19/23 10:51 AM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Thanks all for the replies. Really appreciate them
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: Brad_Haak]
#3185010
10/19/23 11:21 AM
10/19/23 11:21 AM
Posts: 31,050 Oregon
AndyF
I was wondering about plug wire recommendations when I saw this thread pop up. Time to replace my old MSD 8.5s and was looking at a new set of those or Moroso Ultra 40s. Wasn't considering Firecore 50s cuz I build my own wires so that I can run ceramic plug boots where needed due to burning issues. Firecore has a bunch of choices for boots and they'll build custom wire sets if you provide them with the dimensions. I used to have Firecore build all the wires for custom installs when I was doing that stuff.
[Re: AndyF]
#3185040
10/19/23 12:40 PM
10/19/23 12:40 PM
Posts: 1,144 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I was wondering about plug wire recommendations when I saw this thread pop up. Time to replace my old MSD 8.5s and was looking at a new set of those or Moroso Ultra 40s. Wasn't considering Firecore 50s cuz I build my own wires so that I can run ceramic plug boots where needed due to burning issues. Firecore has a bunch of choices for boots and they'll build custom wire sets if you provide them with the dimensions. I used to have Firecore build all the wires for custom installs when I was doing that stuff. Checked yesterday and they don't offer ceramic boots, only the same heat sleeves that I've used with mixed results. Ordered a set of MSD 8.5s a little while ago and will build my own, like usual. Thx
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3185049
10/19/23 01:05 PM
10/19/23 01:05 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
We run nothing but Taylor Spiro Pros.Even with headers on BBs and Sbs never a problem.I do have 7 in an insulated sleeve because the 2 inch tubes are close.Last set on my 440 were 15 years old.Still worked great just looked terrible
Chrysler Firepower
[Re: therocks]
#3185095
10/19/23 04:18 PM
10/19/23 04:18 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
FWIW...I like to build my own so they fit just like I want them to...that rules out Firecores since they won't let you cut and crimp them yourself. Guess they have some magical procedure they do that us normal people can't manage. I've run MSD, Taylor, Moroso, and a set of Firecore wires. No difference in any of them other than the look.
[Re: pittsburghracer]
#3185154
10/19/23 09:27 PM
10/19/23 09:27 PM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
I use Moroso spiral core wires and have for years. The set on my duster are 8 years old and raced weekly during the summer. I like to make my own wires and bought the proper tool to do so years ago.
This is exactly what I do and have for yrs. Ran Moroso and Taylor. No issues with either. I like the ability to make the wires the exact length I want.
Ok
[Re: cudatom]
#3185202
10/20/23 07:40 AM
10/20/23 07:40 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Over the years I have run Accell, Moroso, Taylor, Firecore, MSD, Standard 8.5's and a few others with good results.
I also cut my own wires and working with someone to custom fit a set is not worth the time for me. Easier to have a spool of wire, box of clips and a good crimper.
[Re: DoubleD]
#3185237
10/20/23 10:20 AM
10/20/23 10:20 AM
Posts: 4,570 Motor City
6PKRTSE
Motor City
Don't get hung up on the resistance HP marketing ploy that some put out there - what you want is a good wire with high noise suppression if running an electronic ignition. Resistance of the wire really makes little difference (up to about 500ohm) when hooked to a spark plug (AKA-the load) - its all about getting the power to jump the the gap and make the spark - the circuit is an inductive circuit not a straight DC circuit. Now for wires I have run The Moroso , MSD , Taylor and I have tried the Firecore - there is no real advantage of any of the brands - I will say the Firecore when made to custom fit a given engine - are a pretty good wire because the ends are assembled on machine designed to put the ends on and they are plug and play - so the custom fit service is worth it. . The wire firecore uses is a Delphi GM design was designed for Nascar and Indy racing probably well over 25 years ago - its a good design and well proven - the same wire is used on the Summit House Brand 8.5MM wire. Since I run a HEMI now I like the MSD prostock style wires because they come in red and have the fancy boots with handles! The latest wire out there is the Holley it has one the best Noise suppression and I would recommend that one for anything with electronic fuel injectors. I make all my own wires also. I have used all the different brand names also but Firecore since I make my own. My MSD hemi wires are in black. Since I like the stock look.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Dynoguy]
#3185321
10/20/23 04:22 PM
10/20/23 04:22 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
I like Magnacore as well. Back when I still used plug wires that is.
[Re: 68shifter]
#3185824
10/22/23 11:59 PM
10/22/23 11:59 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
I think I’m going to order a new custom set (FireCore) from Gorski. Had good luck with them, nice product and a good dude He still around here?
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#3186242
10/24/23 07:08 PM
10/24/23 07:08 PM
Posts: 16,487 On the run…
BloFish
On the run…
I think I’m going to order a new custom set (FireCore) from Gorski. Had good luck with them, nice product and a good dude He still around here? He is.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
