Is there a bolt on hub assembly .....
#3183215
10/11/23 08:25 PM
10/11/23 08:25 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
To change the 5.5 front bolt pattern on a 90 truck/ramcharger. To a 4.5 bolt pattern Possible something I can go to the parts store and bring home bolt right on
Reason is. There is crap in wheel selection in a 5.5 pattern Tia
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Is there a bolt on hub assembly .....
[Re: toplescuda]
#3183231
10/11/23 09:41 PM
10/11/23 09:41 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Reason is. There is crap in wheel selection in a 5.5 pattern Tia No. There are tons of 5 on 5 1/2 wheel available.
[Re: NITROUSN]
#3183240
10/11/23 10:18 PM
10/11/23 10:18 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
This is not 4x4 I have yet seen a wheel that looks like a hot rod wheel in a 5.5 I'd like something like this
[Re: toplescuda]
#3183326
10/12/23 11:55 AM
10/12/23 11:55 AM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Thought pre '85 rotors and axles would swap
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3183348
10/12/23 12:52 PM
10/12/23 12:52 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Well the front will be the hardest to get converted. If I can get that lined out. A 8 3/4 rear will be how the back will be done and in the process prob a little more narrow then what has now
[Re: poorboy]
#3183479
10/12/23 08:10 PM
10/12/23 08:10 PM
Posts: 5,907 ohio
ruderunner
ohio
For a 90 truck you should be able to swap on 84 rotors. I don't think the bearings are different in that range.
Angry white pureblood male
[Re: ruderunner]
#3183878
10/14/23 12:25 PM
10/14/23 12:25 PM
Posts: 1,002 rust belt
Moparite
rust belt
I have yet seen a wheel that looks like a hot rod wheel in a 5.5 What does "hot rod wheels" look like? Everybody has different opinions. They look like lambo wheels to me. You may try searching the MM size, A lot of the manufactures use metric 5 x 5.5" (5 x 139.7mm).
[Re: moparx]
#3183924
10/14/23 03:01 PM
10/14/23 03:01 PM
W.I.N. Racing
Byron, NY
A 9.25 rear axle from a pre '85 should suit you as well. If you already have a 9.25 in your truck now you can simply swap axle shafts...
[Re: toplescuda]
#3184000
10/14/23 08:32 PM
10/14/23 08:32 PM
Posts: 8,499 Candler,NC / Myrtle Beach, SC
JDMopar
Go to your local auto parts store and ask them to compare front wheel bearings from a 90 Ramcharger to an 84 Ramcharger. If it's the same bearings, ask the same about rotor diameter. If those are the same, buy new rotors, bearings and brake pads and rock on! I'm going the opposite direction with my 88 D100. It has 5.5 bolt pattern on it, and I am installing an 8 3/4 out of a 72ish half ton. I bought a pair of axles from a 74 Power Wagon 8 3/4 with 5.5 bolt pattern. I'm going to swap them into the housing and use the existing back brakes on the truck.
[Re: W.I.N. Racing]
#3184055
10/15/23 07:53 AM
10/15/23 07:53 AM
Posts: 5,907 ohio
ruderunner
ohio
A 9.25 rear axle from a pre '85 should suit you as well. If you already have a 9.25 in your truck now you can simply swap axle shafts... Wasn't there a change in c clips and side gears to go along with that?
[Re: moparx]
#3184186
10/15/23 04:29 PM
10/15/23 04:29 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
something in the back of my mind is telling me you can get American 5 spokes in a 5.5 bolt pattern. i can't remember where i saw them however. it may have been Speedway Motors. I seen some torque thrust wheels but they was 5 on 5 bolt pattern I have a friend with a 88 said he bought front rotors for a 84 said was direct swap and that only differance between 84/85 was the bolt pattern If this is the case all need to do is the rearend.......that I'd like to install a 8 3/4 and lower the back couple inches
[Re: ruderunner]
#3184360
10/16/23 12:18 PM
10/16/23 12:18 PM
W.I.N. Racing
Byron, NY
A 9.25 rear axle from a pre '85 should suit you as well. If you already have a 9.25 in your truck now you can simply swap axle shafts... Wasn't there a change in c clips and side gears to go along with that? Could be Don't remember all the details but I know its doable. Unfortunately my memory is based on being able to just go to a bone yard and get the parts I needed for such endeavors but probably not so easy any more... As for the front Rotors, an '84 D100/150 and a '92 D150 use the same wheel bearings (inner and outer) NAPA numbers PBR16 (Outer) and PBR11 (Inner)
[Re: W.I.N. Racing]
#3184381
10/16/23 01:48 PM
10/16/23 01:48 PM
Posts: 19,509 north of coder
moparx
https://www.speedwaymotors.com/American-Racing-VN30958576-TTO-Series-Wheel-15-x-8-5,364717.html https://www.speedwaymotors.com/American-Racing-VN3095776-TTO-Series-Wheel-15-x-7,364651.html here is what speedway has for 15" american 5 spoke wheels with a 5 1/2" bolt pattern. 8 1/2" wide, $176.00 each 7" wide, $179.00 each hope this helps.
[Re: volaredon]
#3188072
11/01/23 03:26 PM
11/01/23 03:26 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
The wheels that will be going onto the the r.c.
Had a buddy that has already done it on his truck. Seams the only differance on the front rotors from a earl 80s. And a 85 up is the bolt pattern. Rock auto had hubs for 43 bucks each. So that solved front. I just picked up old taper axel 8 3/4 out of a 60 something truck with a sure gri0 for 50 bucks. So that takes care of the rear Later I may put in normal axels...but for now. Il use as is
