Hemi dynamic compression est. #3183006
10/11/23 10:45 AM
10/11/23 10:45 AM
saint paul mn.
johnzgarage Offline OP
saint paul mn.
I dont have time to access my engine build notes. What would be a ballpark estimated dynamic compression ratio of a 4.15 stroke 472 hemi, with je 98cc pistons and 170cc heads . intake closed 60 abdc . If i remember static was 11.1 . Thanks.
Re: Hemi dynamic compression est. [Re: johnzgarage] #3183022
10/11/23 11:33 AM
10/11/23 11:33 AM
Loudoun County, VA
Brad_Haak Online content
Brad_Haak  Online Content
Loudoun County, VA
Here are two online calculators you can try, but don't be surprised if the results vary significantly because of the difference in how they define the IVC point
http://www.wallaceracing.com/dynamic-cr.php
https://uempistons.com/p-27-compression-ratio-calculator
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Hemi dynamic compression est. [Re: Brad_Haak] #3183095
10/11/23 02:13 PM
10/11/23 02:13 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Sounds about right. Mine is close to that but in a 528 Hemi.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Hemi dynamic compression est. [Re: johnzgarage] #3183105
10/11/23 02:56 PM
10/11/23 02:56 PM
New York
polyspheric Offline
polyspheric  Offline
New York
60 ABDC predicts 9.08:1 DCR and 244 psi CCP
Boffin Emeritus
Re: Hemi dynamic compression est. [Re: polyspheric] #3183336
10/12/23 12:23 PM
10/12/23 12:23 PM
saint paul mn.
saint paul mn.
Thanks for the info ! Saved me some time .
