Re: Hemi dynamic compression est.
[Re: johnzgarage]
#3183022
10/11/23 11:33 AM
10/11/23 11:33 AM
Posts: 1,151 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Here are two online calculators you can try, but don't be surprised if the results vary significantly because of the difference in how they define the IVC point http://www.wallaceracing.com/dynamic-cr.phphttps://uempistons.com/p-27-compression-ratio-calculator
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3183095
10/11/23 02:13 PM
10/11/23 02:13 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
Sounds about right. Mine is close to that but in a 528 Hemi.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: johnzgarage]
#3183105
10/11/23 02:56 PM
10/11/23 02:56 PM
Posts: 4,210 New York
polyspheric
New York
60 ABDC predicts 9.08:1 DCR and 244 psi CCP
Boffin Emeritus
