Re: Where to mount remote oil filter ?
[Re: topside]
#3183121
10/11/23 04:00 PM
10/11/23 04:00 PM
Posts: 2,926 A shed in England
Tig
A shed in England
I've had mine fitted on the rad support since we fitted the oil accumulator in 2012. Never been an issue. You can just make out the billet mount to the right of the radiator.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3183135
10/11/23 05:02 PM
10/11/23 05:02 PM
Posts: 4,441 Michigan
MarkZ
Worthy
Worthy
I mounted mine behind the bumper with the bottom of the filter at the same height as the bottom of the bumper. Not a race car by any stretch, but it works and doesn't make a mess.
[Re: '72CudaRacer]
#3183172
10/11/23 06:12 PM
10/11/23 06:12 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I mounted mine to the motor plate, above the oil pump and beside the water pump. No issues and very easy to change the filter. This a big block, race only E- body.
Brian Mine is in the same place.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: HardcoreB]
#3183278
10/12/23 09:19 AM
10/12/23 09:19 AM
Posts: 8,881 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I mounted mine behind the bumper with the bottom of the filter at the same height as the bottom of the bumper. Not a race car by any stretch, but it works and doesn't make a mess. I like this. Mine's not a race car either.
[Re: HardcoreB]
#3184801
10/18/23 12:12 PM
10/18/23 12:12 PM
Posts: 16,928 NC
440Jim
NC
Here's one I just did that is that sandwiches the motorplate between the OFA and the vacuum pump. It also happens to be accessible thru the K-member ears. HardcoreB, I like the way you did that.
[Re: 440Jim]
#3184810
10/18/23 12:29 PM
10/18/23 12:29 PM
Posts: 4,066 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Here's one I just did that is that sandwiches the motorplate between the OFA and the vacuum pump. It also happens to be accessible thru the K-member ears. HardcoreB, I like the way you did that. Thanks Jim! It worked really well until i redid the plumbing, I flipped the engine over to get a better view of how I could reroute the lines and that's when I didn't notice 'the bottom port was now, the top port...that cost me pretty good. It had some non-typical packaging compromises but, again I like the fact that you dont have to remove oil lines if you pull the engine. On my own junk, i currently have it mounted to the frame because that was about the best choice considering everything.
[Re: HardcoreB]
#3185059
10/19/23 01:36 PM
10/19/23 01:36 PM
Posts: 16,928 NC
440Jim
NC
Yea, I hear Ya. On my Daytona, I put a semi-permanant label on one of the remote filter lines that says, "top port" It saves time and avoids mistakes when I take the lines off the pump. OK... which port is the Inlet, and which the Outlet? ....
