One piece oil pan gasket - do you use silicone? #3182908
10/10/23 09:29 PM
10/10/23 09:29 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I am changing to a one piece oil pan gasket. I picked it up’s from. Mancini
I usually use silicone. Does this type use hi temp silicone?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: One piece oil pan gasket - do you use silicone? [Re: Kam*Kuda] #3182910
10/10/23 09:32 PM
10/10/23 09:32 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I don't think that type of gasket will require any kind of RTV or sealer.
Re: One piece oil pan gasket - do you use silicone? [Re: Kam*Kuda] #3182924
10/10/23 10:03 PM
10/10/23 10:03 PM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
No silicone required. I have zero leaks with that piece.
Hutch
Re: One piece oil pan gasket - do you use silicone? [Re: Kam*Kuda] #3182953
10/11/23 04:01 AM
10/11/23 04:01 AM
No, install it dry up I do wrench uptwocents
Re: One piece oil pan gasket - do you use silicone? [Re: Kam*Kuda] #3183092
10/11/23 02:04 PM
10/11/23 02:04 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Silicone RTV is the the mis-used chemical in the automotive marketplace. Simple rule-of-thumb: Never apply RTV over/across a rubber gasket. It should only be used as a filer of gap .. such as intersecting corners of multiple gaskets (intakes, oil pans, etc.... just a little dab to fill the gap. Rubber gaskets are always best installed DRY.
Re: One piece oil pan gasket - do you use silicone? [Re: Mopar Mitch] #3183372
10/12/23 02:26 PM
10/12/23 02:26 PM
moparx Offline
moparx  Offline
follow the old Brylecream jingle when using RTV : "just a little dab will do ya !" up
beer
Re: One piece oil pan gasket - do you use silicone? [Re: Kam*Kuda] #3183669
10/13/23 03:40 PM
10/13/23 03:40 PM
Mopar Mitch Offline
Mopar Mitch  Offline
In addition to NOT using any chemical sealant what-so-ever, since this gasket design has a metal internal core, it truly has very little compressability... barely any forgiveness to out-of-flat conditions. SO... make absolutely certain that your oil pan is FLAT at the side rails... fix or replace it IF the bolt holes are distorted from previous over-tightening, etc.
Re: One piece oil pan gasket - do you use silicone? [Re: Kam*Kuda] #3184522
10/17/23 05:35 AM
10/17/23 05:35 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Don't use sealer unless there is some issue with the oil pan.
The sealer will actually eat into the sealing ribs of the molded windage tray gasket. It will still seal, but if you ever remove the tray, the sealing ribs where the sealer was will look like they were mixed into the RTV sealer.
I have a used windage tray like that, I should take a photo of it.
I also widen the windage slots a bit.
