440/727 towing combination #3180598
10/03/23 02:14 PM
10/03/23 02:14 PM
High Plains of South Dakota
O
olwhite64 Offline OP
O
Since my boy is now a racer, we need another tow rig. Going to convert my '86 D-150 (318/Auto) over to big block power to do the job. This truck will be hooked onto an open 18' steel/wood deck trailer towing a B-body 80 miles (roundtrip) to the track maybe 8-10 times a year; plus occasional trips to the local tavern with my bride.
I snagged up an '81 Dodge RV with 61,xxx miles on the odometer. 440/long-tail 727. Just doing some really basic stuff to the 440 (reseal, headers, Performer RPM intake, 600 Edelbrock, maybe a cam for towing if anyone has any ideas) as well as converting it to an 8 3/4 with 3.55's. Of course, I'll add a large auxiliary cooler to the trans (and maybe the engine oil too?).
My questions really center around the transmission.
Research tells me RV-spec tranny's should have some good stuff already (4 pinion planetary's, extra clutch, etc.).
Any recommendations on internal upgrades or just clean/freshen/replace what's already in there?
How about a shift kit?
The converter that is currently in the transmission has a large ring gear but also has a sticker on it that says "low-stall".
I suspect they used these to get these giant bread-box lumbering barges moving?
So, maybe the converter is perfect for the application?
Any other thoughts/concerns I'm not seeing?
Re: 440/727 towing combination [Re: olwhite64] #3180808
10/04/23 01:29 AM
10/04/23 01:29 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
The transmission does have heavy duty internals.while apart I would put a transtar rv converter in it.
Re: 440/727 towing combination [Re: d-150] #3180886
10/04/23 10:28 AM
10/04/23 10:28 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
I have a 74 Ramcharger that's a factory 440 truck and in the last few years I've driven it over 800 miles. It's fun, loud, all stock except for suspension with 3.54 gearing in the D60/D70 axles with 33" tires. I'm averaging 6.8mpg. If I was to build an older dodge truck to tow with, I'd use a 360 magnum block and make it a 408 stroker.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: 440/727 towing combination [Re: shanker] #3180911
10/04/23 11:55 AM
10/04/23 11:55 AM
moparx Offline
moparx  Offline
i would recommend a TF-2 shift kit.
beer
Re: 440/727 towing combination [Re: moparx] #3180939
10/04/23 12:46 PM
10/04/23 12:46 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
That or at least raise fluid pressure cheap tighten up shifts
Re: 440/727 towing combination [Re: shanker] #3181107
10/04/23 08:22 PM
10/04/23 08:22 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Those 33" tires are what is killing your mpg. It takes a lot of throttle to get them rolling. Then, has your speedo been calibrated to the big tires?
So is a 408 stroker motor any more fuel efficient then a 440 with a good towing cam?
I've pulled a car trailer with a factory 440, and I've pulled that same trailer with a 360 in a truck, the 360 did OK, but didn't hold a candle to the 440 truck, and both got the same gas mileage pulling that trailer (about 9mpg).
I've never had a 408 Stroker, so I have no comparison between it and a 440.
Re: 440/727 towing combination [Re: poorboy] #3181253
10/05/23 09:07 AM
10/05/23 09:07 AM
O
O
All good stuff fellas - keep it coming
Think I should call Comp for a cam recommendation or will that be waste of time?
Re: 440/727 towing combination [Re: olwhite64] #3181281
10/05/23 10:06 AM
10/05/23 10:06 AM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
If towing no .u got the best cam possible for that.
Re: 440/727 towing combination [Re: olwhite64] #3181283
10/05/23 10:11 AM
10/05/23 10:11 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Deep trans pan. Coated headers to control heat.
I’d run a larger vacuum carb. A 600 is smaller than a lo po 440 had. A tq would be good and is what factory 440 trucks had for years. I’d want as much power as I could get when towing. Guys can do what they want, argue this all they want, but a bigger carb doesn’t kill low end like is claimed. The secondary’s will come in as needed. That’s been my experience running a big carb after a small one and the seeing the results.
I want my fair share
Re: 440/727 towing combination [Re: SomeCarGuy] #3181466
10/05/23 06:17 PM
10/05/23 06:17 PM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
I'd consider swapping to an 8 lug D60 rear and upgrade the front brakes to 8 lug as well. The 440 won't have trouble moving the trailer but the bigger brakes and stiffer tires will help control things better.
Angry white pureblood male
Re: 440/727 towing combination [Re: olwhite64] #3181597
10/06/23 09:00 AM
10/06/23 09:00 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Sounds like a lot of work for something the 318 would handle….. this ole beater made a ton of treks from Aberdeen to TVD open trailer with race car smile 318/727
Re: 440/727 towing combination [Re: J_BODY] #3181604
10/06/23 09:21 AM
10/06/23 09:21 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
I agree. For that little use the most I would do is install some 3.91 gears. If the trailer is set up the way it should be with brakes on both axles it will stop just fine.
Re: 440/727 towing combination [Re: NITROUSN] #3181892
10/07/23 11:36 AM
10/07/23 11:36 AM
Central NC
gch Offline
gch  Offline
Central NC
No farther than you are going you could spend some money on the 318 or swap in a 360, Unless hills are involved. A 408 Stroker would give you big block torque in a small block package provided the heads could move enough air.
A 360 magnum with hyd roller cam would likely do just fine for a lot less money.
I love my big blocks but don't look forward to that much work any longer.
Re: 440/727 towing combination [Re: J_BODY] #3182696
10/10/23 10:42 AM
10/10/23 10:42 AM
O
O
Man I dig those Mirada wheels on that truck - after I swap mine to 4 1/2" BP I'll have to hunt down a set!
The reason for the swap is the ol' 318 is really tired and the trans is some kind of version of a 904 - just figured since I had all the parts the swap made sense.
Re: 440/727 towing combination [Re: olwhite64] #3182705
10/10/23 11:32 AM
10/10/23 11:32 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Torque for that application is King, as well as keeping highway RPM in the meat of the torque curve, usually around 2600-2800 RPM.
MPG benefits when using as little throttle opening as possible while pulling.
While my 408 made very good TQ in a Duster, it didn't compare to an RB.
Thermoquads are great in that application, 2nd best a vac-secondary.
I'd use the existing MH converter. Shift kits are a good thing, as they reduce the shift overlap; doesn't need anything racy.
Since the OP already has the MH 440/727 and the 318 is tired, the path forward seems pretty obvious.
Make sure you can cool it, and add an ATF cooler. I like deep pans on everything.
Re: 440/727 towing combination [Re: olwhite64] #3182733
10/10/23 12:39 PM
10/10/23 12:39 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Mike Jones has a grind specifically for the motorhome big block engines. It ain't cheap, but you get what you pay for. If I was to make one change other than what you have mentioned it would be the cam. The smallest lunati voodoo would be a distant second choice.
No more than you will be driving it though there is nothing wrong with keeping the oem cam if it is in good shape. Won't get quite the same power but it will be well above what the 318 was on its best day anyway.
Trans cooler and shift kit would be on my list as well. OEM low stall converter is good for this application. It will help keep the revs down and give a little better mileage since it is likely not a lock up converter.
Re: 440/727 towing combination [Re: mgoblue9798] #3183005
10/11/23 10:39 AM
10/11/23 10:39 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
ramp truck , close thread
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 440/727 towing combination [Re: bigdad] #3183294
10/12/23 10:12 AM
10/12/23 10:12 AM
O
O
LOL - You build me one 'Dad and I'll put Brownie in the weeds!
Re: 440/727 towing combination [Re: mgoblue9798] #3183295
10/12/23 10:13 AM
10/12/23 10:13 AM
O
O
How do I find out about Mike Jones? Did a search and the commonality of his name about put Google into a tailspin...
Re: 440/727 towing combination [Re: olwhite64] #3183337
10/12/23 12:24 PM
10/12/23 12:24 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
http://jonescams.com/
