Question for the 2nd gen ram truck enthuthiasts #3182081
10/08/23 12:18 AM
10/08/23 12:18 AM
Sonoran desert, Arizona, USA
moparjo68 Offline OP
Hello. I have the 99 Dodge Ram 2500 v10 in the Sport edition. Last nite I messed up my back bumper beyond repair. My question is: Will the back bumper fit on my truck from any 2nd gen ram truck or does it have to be the Sport model? I know the plastic front bumper is unique to the Sport edition and not the other trucks. So I was hoping the rear bumper would fit from any 2nd gen ram truck. Fingers crossed someone can help me with this. Thanks
Re: Question for the 2nd gen ram truck enthuthiasts [Re: moparjo68] #3182090
10/08/23 05:30 AM
10/08/23 05:30 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
Yes any bumper will work
Re: Question for the 2nd gen ram truck enthuthiasts [Re: moparjo68] #3182092
10/08/23 05:43 AM
10/08/23 05:43 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The main difference is that the rear bumper on a Sport is painted body color rather than black or chrome.
Re: Question for the 2nd gen ram truck enthuthiasts [Re: moparjo68] #3182094
10/08/23 06:54 AM
10/08/23 06:54 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I certainly like the 2nd Gen Ram design’s many innovations, but the rear bumper does not impress me.
I see so many rear bumpers rusted out,
and in the mild rear end collision I suffered in 2004 and the others I have seen the rear bumper seems kinda “window dressing” like and cannot withstand even the mildest tap.
I am old enough to remember the “5 mph bumper” era and the wide range of good and bad designs back then.
I see those “tall boy” beer and energy drink cans and wonder about a custom rear bumper with those to absorb shock.
Maybe empty such cans and refill with expanding urethane foam.
A horizontal “whirlwind” forms behind the tailgate at highway speed and it is possible that a “half pipe” bumper of some sort could improve fuel economy.
The weird “side triangles” of GM Avalanches behind and on the sides of the rear cab window are designed to stabilize the horizontal whirlwind that forms behind the cab and at the front of the cargo box. Early Honda Ridgelines did similar.
Re: Question for the 2nd gen ram truck enthuthiasts [Re: 360view] #3182096
10/08/23 07:20 AM
10/08/23 07:20 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I can't speak for GM but Honda's "sail panel" was to support the unibody that they since engineered out.
As for the OP there are plenty o aftermarket bumpers for GEN II.
Re: Question for the 2nd gen ram truck enthuthiasts [Re: redraptor] #3182117
10/08/23 10:52 AM
10/08/23 10:52 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Don't like the bumper use a roll pan.
Re: Question for the 2nd gen ram truck enthuthiasts [Re: Moparite] #3182122
10/08/23 11:26 AM
10/08/23 11:26 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Roll pan won't help if you get hit or back into something. shruggy
Re: Question for the 2nd gen ram truck enthuthiasts [Re: stumpy] #3182124
10/08/23 11:32 AM
10/08/23 11:32 AM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
Those bumper r harder then newer ones
Re: Question for the 2nd gen ram truck enthuthiasts [Re: d-150] #3182168
10/08/23 01:39 PM
10/08/23 01:39 PM
And the 2nd gen years run from 1994 thru AND INCLUDE model year 2002. Is that correct? A 2003 bumper would not fit?
Re: Question for the 2nd gen ram truck enthuthiasts [Re: moparjo68] #3182184
10/08/23 02:07 PM
10/08/23 02:07 PM
moparx Offline
moparx  Offline
weld up a chunk of 4" water pipe to your stock brackets for a "slightly" better rear bumper. biggrin
beer
Re: Question for the 2nd gen ram truck enthuthiasts [Re: moparjo68] #3182207
10/08/23 03:11 PM
10/08/23 03:11 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
New bumper from Rock Auto is pretty cheap, chrome ones anyway.
Re: Question for the 2nd gen ram truck enthuthiasts [Re: Sniper] #3182327
10/08/23 11:11 PM
10/08/23 11:11 PM
I would rather find a good used one than buy aftermarket. Thats why I'm trying to pinpoint the year that Gen 2 ram trucks ended. From what I have read, Gen 2 ended with model year 2002, is that correct?
Re: Question for the 2nd gen ram truck enthuthiasts [Re: moparjo68] #3182328
10/08/23 11:36 PM
10/08/23 11:36 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
1500's no, ended 2001, 2500's and 3500's ended in 2002
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Question for the 2nd gen ram truck enthuthiasts [Re: moparx] #3182359
10/09/23 07:35 AM
10/09/23 07:35 AM
USA
3
360view Offline
360view  Offline
3
USA
beer
Many mining operations use high density polyethylene pipe to pump mixtures of rock and water.
Our 16” OD 1.5 wall HDPE pipe would wear out after four years.
The outside wall of the pipe would be scratched up too, as bulldozers would push or drag them.
We could give the old worn pipes away to county road departments for under road drains.
I never thought about using HDPE pipe as a truck bumper.
You could even slip a smaller OD pipe inside.
The Phosphate mines of Florida, and the “china clay” TiO2 mines of Georgia also use such HDPE pipe.
Re: Question for the 2nd gen ram truck enthuthiasts [Re: 360view] #3182400
10/09/23 11:23 AM
10/09/23 11:23 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Dirt gets trapped between the inner support and the bumper. That is why you see so many rusted ones.
Re: Question for the 2nd gen ram truck enthuthiasts [Re: 3hundred] #3183132
10/11/23 05:01 PM
10/11/23 05:01 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Exactly 1500s ended in 2001, 2500 & 3500 ended in 2002 (I still have my 2002 2500 Cummins - yay!! . . . )
Cheers
Mark
Re: Question for the 2nd gen ram truck enthuthiasts [Re: a12rag] #3183176
10/11/23 06:16 PM
10/11/23 06:16 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I still have my 96 V10 4x4. 2nd owner since 98 and has been flawless. Never let me down and everything still works. However, Michigan winters are killing the body.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Question for the 2nd gen ram truck enthuthiasts [Re: 6PKRTSE] #3183212
10/11/23 08:18 PM
10/11/23 08:18 PM
I'm fortunate to live in a rust-free state. My 99 Ram 2500 has zero rust. It has been an Arizona truck 99% of its live. It spent a year or so in Colorado. Otherwise, its been in Arizona. I used to live in the rustbelt and I know what salty roads does to the vehicles. BTW..............nice truck a12rag
