Re: Aftermarket valley pan?
[Re: AndyF]
#3182057
10/07/23 09:19 PM
10/07/23 09:19 PM
Posts: 2,141 junction city oregon
viperblue72
Thank you Andy. I might throw a single plane on it just to remedy this issue. It makes plenty of torque anyways. It’s 10 to 1 with fully ported sidewinder heads. Trickflow 243@050/.600 cam. I have a 3500 stall and 4.88 gear with 36” tires. What all does your valley tray work with? It’s currently a rpm.
[Re: AndyF]
#3182116
10/08/23 10:43 AM
10/08/23 10:43 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Some of the older design single planes that utilize a heat crossover will have that crossover hanging down below the bottom edge of the mounting flange.
Since the Sidewinder heads have no heat riser port, if the crossover hits the valley cover it can just be removed.
[Re: B1MAXX]
#3182680
10/10/23 09:39 AM
10/10/23 09:39 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Make your own using the Fel Pro
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
