Toe Guage Options. #3181891
10/07/23 11:35 AM
10/07/23 11:35 AM
IMGTX Offline OP
IMGTX  Offline OP
I am looking at getting an alignment Toe Gauge.
Here are two I am looking at but would love ideas on what is best.
I like these for the dual tape measures that make it easy to get the measurement but is it really accurate?
https://www.amazon.com/dp/B0B4R7P28Y
This one is sturdy.
Many with the bar between the wheels are flimsy bars that seem like they would bend and throw off the measurement.
https://www.amazon.com/gp/product/B01N26KYGL
Most important what is the best affordable one?
Re: Toe Guage Options. [Re: IMGTX] #3181903
10/07/23 12:02 PM
10/07/23 12:02 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Two straight pieces of angle iron/box tubing/etc will suffice.
No need for fancy stuff,
Re: Toe Guage Options. [Re: Sniper] #3181912
10/07/23 12:26 PM
10/07/23 12:26 PM
moparx Offline
moparx  Offline
i agree.
just take your time measuring and adjusting. you can do it. up
beer
Re: Toe Guage Options. [Re: Sniper] #3181915
10/07/23 12:31 PM
10/07/23 12:31 PM
IMGTX Offline OP
IMGTX  Offline OP
Thank you. I like that idea.
Glad I asked before I spent the money. up
I guess I was way overthinking it.
Re: Toe Guage Options. [Re: moparx] #3181932
10/07/23 01:37 PM
10/07/23 01:37 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
i agree.
beer
A friend of mine uses two florescent light bulbs wink
Re: Toe Guage Options. [Re: A12] #3182052
10/07/23 08:58 PM
10/07/23 08:58 PM
A727Tflite Offline
A727Tflite  Offline
Is there a standard for how far forward of the spindle you check toe?
Re: Toe Guage Options. [Re: A727Tflite] #3182059
10/07/23 09:22 PM
10/07/23 09:22 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
A good friend loaned me the toe plates like you posted above. Working by myself I couldn’t get it set right. I bought the bolt on ones from I think Amazon and used 4 plumb bobs and two tape measures and set it up perfect.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Toe Guage Options. [Re: A727Tflite] #3182173
10/08/23 01:46 PM
10/08/23 01:46 PM
moparx Offline
moparx  Offline
that will depend on the tire diameter.
i suppose 13 or 14" would be a happy medium ? [26-28" tire diameter] shruggy
beer
Re: Toe Guage Options. [Re: moparx] #3182210
10/08/23 03:31 PM
10/08/23 03:31 PM
A727Tflite Offline
A727Tflite  Offline
beer
Well, I don’t recall a toe in spec difference between wheel diameters. And next question, when using aftermarket tools without wheels.
Of course I am talking about when inches are mentioned and not degrees.
Re: Toe Guage Options. [Re: A727Tflite] #3182287
10/08/23 08:21 PM
10/08/23 08:21 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I've been using one like this for 35 years. I like it because it is quick and easy to use. Yes, the long bar is a bit flimsy, but it doesn't matter because when you pull it tight, it is straight.
https://www.amazon.com/VKRP-Distributors-Wheel-Alignment-Toe-in-Toe-Out-Gauge/dp/B01CB26JXQ
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Toe Guage Options. [Re: Hemi_Joel] #3182291
10/08/23 08:34 PM
10/08/23 08:34 PM
nowhere
nowhere
Problem with all those methods is that you want the toe to be equal side to side. You could have 1/4" toe in on one side an 1/8" toe out on the other side ant those methods will tell you that you have 1/8" toe in overall and while being technically correct your tire will wear funny.
http://speed.academy/diy-wheel-alignment-how-to-guide-explained/2/
Re: Toe Guage Options. [Re: Sniper] #3182295
10/08/23 08:38 PM
10/08/23 08:38 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
If it is not the same side to side, the steering wheel will not be straight when you are driving.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Toe Guage Options. [Re: Sniper] #3182299
10/08/23 08:47 PM
10/08/23 08:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Ummm, your example would result in 3/16" toe and a slightly offset steering wheel.
Re: Toe Guage Options. [Re: Hemi_Joel] #3182309
10/08/23 09:55 PM
10/08/23 09:55 PM
nowhere
nowhere
True, but it will be straight when aligning it, which will mess up your thinking, lol.
Re: Toe Guage Options. [Re: A727Tflite] #3182456
10/09/23 01:20 PM
10/09/23 01:20 PM
moparx Offline
moparx  Offline
beer
you are correct about the toe in being the same between wheel diameters, however, if you start out with 13" wheels with 1/8" toe in, then switch to 20" wheels without resetting the toe, you will instantly see the toe in is severe.
just the math difference in the diameter of the wheels putting them closer together in the front.
that was why i just suggested a figure out of the air, because i don't know what you are choosing for tire/wheel combination, and you are [i think] working with a bare rotor, setting the toe from it.
beer
Re: Toe Guage Options. [Re: IMGTX] #3183168
10/11/23 06:04 PM
10/11/23 06:04 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
