oil flow Question #3181535
10/05/23 10:28 PM
10/05/23 10:28 PM
sc
tjmarcus1 Offline OP
sc
[b][/b] 360 magnum does the oil flow into the filter from the center hole?
Re: oil flow Question [Re: tjmarcus1] #3181566
10/06/23 12:03 AM
10/06/23 12:03 AM
New York, USA
Chargerfan68 Offline
New York, USA
I’m not an expert on this subject but from what I know, most , if not all mopar engines filter the oil from the outside of the filter to the center. Cutting a filter apart for inspection is done by looking at the outside of the filter material for debris.
Re: oil flow Question [Re: tjmarcus1] #3181568
10/06/23 12:08 AM
10/06/23 12:08 AM
No, the oil flows back from the oil filter through the hollow bolt into the block oil passage, if I'm remembering correctly work scope
The rubber anti drain back flap in the top of the oil filters is design to keep the oil in the filter with no oil pressure, it only allows oil to flow under pressure scope twocents
Re: oil flow Question [Re: tjmarcus1] #3181573
10/06/23 02:13 AM
10/06/23 02:13 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
