Master cylinder question #3180543
10/03/23 11:18 AM
10/03/23 11:18 AM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
What master cylinder for 4 wheel manual disc? Thanks
Re: Master cylinder question [Re: bobs69] #3180550
10/03/23 12:01 PM
10/03/23 12:01 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I’m using a 15/16” master cylinder from Doctor Diff with my manual 4 wheel discs, pedal takes a bit of effort but I like the feel drive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Master cylinder question [Re: bobs69] #3180558
10/03/23 12:26 PM
10/03/23 12:26 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Swapped from a 1 1/32 to a 7/8 bore. It was way better, no more both feet braking on the 140mph + short shut downs grin.
For info we have Wilwoods all round.
Re: Master cylinder question [Re: bobs69] #3180588
10/03/23 01:54 PM
10/03/23 01:54 PM
The smaller bores, under 1.0 in diameter, stop better than the larger ones over 1.0 inch diameter, way better the smaller you make them up twocents
Re: Master cylinder question [Re: bobs69] #3180701
10/03/23 07:46 PM
10/03/23 07:46 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Depends. 2 piston? 4 piston? How many of each? How big are the bores?
Re: Master cylinder question [Re: Cab_Burge] #3180703
10/03/23 07:47 PM
10/03/23 07:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
True. Will make more pressure than the large bores. But the reduced volume may make the amount of pedal travel unacceptable or unsafe.
Re: Master cylinder question [Re: bobs69] #3180720
10/03/23 08:12 PM
10/03/23 08:12 PM
AndyF Offline
AndyF  Offline
That is like asking what camshaft to use for a race engine. As luck would have it, the answer is the same. Use the one that matches the rest of the parts in the system.
Re: Master cylinder question [Re: AndyF] #3180735
10/03/23 08:46 PM
10/03/23 08:46 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Actually my question wasn’t about crankshafts. I know about engine building. Just bought this car with a bad master cylinder. Looking for a starting point with the brakes. If you can help thank you if not I don’t need the sarcasm. Thanks
Re: Master cylinder question [Re: bobs69] #3180834
10/04/23 07:31 AM
10/04/23 07:31 AM
PA
moparacer Offline
moparacer  Offline
PA
Like Cole said, you need to base your master cylinder size on your brake system volume.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
