Re: Master cylinder question
[Re: bobs69]
#3180558
10/03/23 12:26 PM
10/03/23 12:26 PM
Posts: 2,933 A shed in England
Tig
A shed in England
Swapped from a 1 1/32 to a 7/8 bore. It was way better, no more both feet braking on the 140mph + short shut downs . For info we have Wilwoods all round.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: bobs69]
#3180701
10/03/23 07:46 PM
10/03/23 07:46 PM
Posts: 11,655 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
What master cylinder for 4 wheel manual disc? Thanks Depends. 2 piston? 4 piston? How many of each? How big are the bores?
[Re: bobs69]
#3180720
10/03/23 08:12 PM
10/03/23 08:12 PM
Posts: 31,067 Oregon
AndyF
What master cylinder for 4 wheel manual disc? Thanks That is like asking what camshaft to use for a race engine. As luck would have it, the answer is the same. Use the one that matches the rest of the parts in the system.
[Re: bobs69]
#3180834
10/04/23 07:31 AM
10/04/23 07:31 AM
Posts: 2,524 PA
moparacer
PA
Actually my question wasn’t about crankshafts. I know about engine building. Just bought this car with a bad master cylinder. Looking for a starting point with the brakes. If you can help thank you if not I don’t need the sarcasm. Thanks Like Cole said, you need to base your master cylinder size on your brake system volume.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
