426 windage tray issues #3179824
10/01/23 10:34 AM
10/01/23 10:34 AM
Southeast Virginia
68jim Offline OP
68jim  Offline OP
Southeast Virginia
While chasing down an oil leak last month I installed one of those Mancini rear main seals - leaks worse now but not the topic here. While I had the oil pan off, I thought it would be a good idea to swap the original style windage tray w/2 gaskets over to the one-piece tray/gasket combo. There were a few scratches on the steel tray from where the connecting rod hardware had hit it, and a previous owner dimpled the areas for extra clearance. Anyway, I assumed that maybe the tray was a little bent and that was an easy fix at the time. So, I install the one-piece tray and it is so much nicer than mucking around with the extra gaskets and such. When I started the car up it sounds like a bunch of drummers going at it in the oil pan. You can certainly feel the thumping/vibrations with your hand on the bottom of the pan. Has anyone else come across this before? Is this not an issue with the 440 even with the same 3.75" stroke but smaller rod hardware? I'm thinking now that perhaps I need to change it out for the deeper one-piece designed for a 4.15" stroke to get the extra clearance. Thoughts?
68jim
Re: 426 windage tray issues [Re: 68jim] #3179883
10/01/23 01:51 PM
10/01/23 01:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
Sounds like you need to check the rotating parts to the tray clearances before installing the oil pan up scope
I do that on all of my stroker motor builds while the motor is on the engine stand, I roll the motor over and look through the tray while rotating the motor over in 90 degree increments to make sure nothing hits. I normally use a stock Mopar brand steel windage tray with strokes up to 4.25 with BB chevy rod journals sizes and steel H and I beam rods with none hitting so far luck
I can't remember on using a 4.150 stroke crank with stock Mopar rod journals sizes and steel rods but I think they clear also confused shruggy
You can also check that with the timing cover off with the oil pan on and use a flashlight or some other additional lighting wrench scope
Re: 426 windage tray issues [Re: Cab_Burge] #3179950
10/01/23 06:19 PM
10/01/23 06:19 PM
Southeast Virginia
68jim Offline OP
68jim  Offline OP
Southeast Virginia
Cab,
Thanks for chiming in. I will go ahead and order the one-piece used with the 4.15" stroke. Once I drop the pan again I will mock up to see what is going on. The one-piece and the steel windage tray had the same height but then you have to add in the thickness of the gasket which drops the steel tray lower into the pan. The plastic one can't be tweaked like the steel one so it either fits or it don't. The only other option I see would be to create small slots in the plastic pan to allow clearance for the rod hardware...
68jim
Re: 426 windage tray issues [Re: 68jim] #3182567
10/09/23 07:34 PM
10/09/23 07:34 PM
Southeast Virginia
68jim Offline OP
68jim  Offline OP
Southeast Virginia
Update from this weekend's efforts - I dropped the pan again and the plastic tray had several gouges, which is pretty much as I expected. I got a new tray from Jegs to fit for a 4.15" stroker crank. Mocking it up showed that it had plenty of extra clearance so good to go. Firing the motor up afterwards had good results and no more drumming from the bottom end. The rear main seal issue was corrected by removing the billet aftermarket unit and putting the factory style back in...no more leaks! I took some pictures of the rod hardware but I have no idea if the bolts are stock or aftermarket. The motor was built about 33 years ago so not sure what was available back then. I wonder if this might be more of a Hemi issue since never had it on any 440 previously.
68jim
steel windage tray.jpgplastic 3.75 windage tray.jpghemi rod hardware.jpghemi rod hardware 2.jpg
Re: 426 windage tray issues [Re: 68jim] #3182581
10/09/23 08:04 PM
10/09/23 08:04 PM
AndyF Offline
AndyF  Offline
Sounds like it is an old-school build with a 4.150 stroke and Mopar size rods. Those old strokers used up a lot of volume in the crankcase. A lot of aftermarket parts are now designed for strokers with the newer 2.200 rods.
Re: 426 windage tray issues [Re: AndyF] #3182678
10/10/23 09:35 AM
10/10/23 09:35 AM
Southeast Virginia
68jim Offline OP
68jim  Offline OP
Southeast Virginia
Andy - thanks for chiming in. Pretty sure it is not a stroker crank since I can see the part number stamped on a counterweight vertically (2780533), that crosses over to a stock hemi crankshaft. One thing I did notice is that the plastic one and the stock steel tray have the identical height (best I could measure) The steel one ends up farther down in the pan a little bit since it also has a gasket in-between the tray and the block. Looked like I picked up about 3/16" extra clearance with the deeper tray.
68jim
Re: 426 windage tray issues [Re: 68jim] #3182682
10/10/23 09:56 AM
10/10/23 09:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
68jim
The rod bolt with the dimple on the end, it probably has them on both ends, is an aftermarket bolt. The dimple, I believe, is to retain a bolt stretch gauge better .
Re: 426 windage tray issues [Re: 68jim] #3182746
10/10/23 01:14 PM
10/10/23 01:14 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That's bizarre. By all rights either one should work and the don't.
I wonder how those compare to the production style tray.
Rich H.
Esse Quam Videri
Re: 426 windage tray issues [Re: ZIPPY] #3182768
10/10/23 02:22 PM
10/10/23 02:22 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
In 2004 I bought a stock 426 Hemi crank, rods and windage tray from Ma Mopar. The rods hit the windage tray. Which I thought would be impossible.
2011 Drag Pak Challenger
Re: 426 windage tray issues [Re: 68jim] #3186078
10/24/23 01:38 AM
10/24/23 01:38 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
On my latest Hemi build I decided to use the new tray and after rotating the engine by hand I noticed it was scraping the crank. I took a cutoff wheel and made slots where the rods were hitting and that cured it.
Re: 426 windage tray issues [Re: 52savoy] #3186200
10/24/23 03:36 PM
10/24/23 03:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Hemi rods-bolts ARE bigger than 440 rods. Aren’t deeper trays going against the grain for oil issues (to far from crank)? A hall peen hammer will fix those marks in tray, I’d do that first.
Re: 426 windage tray issues [Re: cudaman1969] #3186255
10/24/23 07:44 PM
10/24/23 07:44 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Are those HEMI rods? The rod nuts look larger than normal or is it just the camera angle work
Gus beer
64 Plymouth Savoy
Dana 60
Re: 426 windage tray issues [Re: fourgearsavoy] #3186401
10/25/23 12:40 PM
10/25/23 12:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gus beer
Crossbolted maincaps , looks like a hemi.
Re: 426 windage tray issues [Re: cudaman1969] #3186454
10/25/23 03:18 PM
10/25/23 03:18 PM
Southeast Virginia
68jim Offline OP
68jim  Offline OP
Southeast Virginia
The previous owner did just that except with a punch (first picture - you can see the scratch in the punch marks) The whole idea was to get rid of the tray with 2 gasket combo while I had things opened up to fix the leaking rear main seal issue. I did consider cutting notches in the plastic tray and I'm sure it would have worked OK but that also would have been a lot easier with the motor upside down on a stand vice installed in the car. JEGS had the stroker tray on sale and it was a decent deal, so I went that route. Best I could measure with the stroker tray was that I now had about 1/8" to 3/16" clearance. Not sure what the factory intended as far as rod/hardware clearance to the windage tray but think I'm OK with this arrangement. One thing I did notice about the damage on both trays was that it was more pronounced towards the rear of the motor - Evidently the crank centerline is not exactly parallel to the bottom rail?? Or more likely it may have been how the trays were manufactured?? The bigger issue I see is that the new plastic trays do not account for the extra depth you gain with a gasket. The plastic one-piece and the steel factory tray had identical heights when set up side by side.
Yes, this is a Hemi and not a 426 Wedge - good eye catching the cross-bolted main...
jim
