Rocker arm adjuster nut torque #3177688
09/24/23 09:22 AM
09/24/23 09:22 AM
Detroit area
6PAX Online content OP
6PAX  Online Content OP
Detroit area
When I installed my adjustable rocker arms (Comp Pro Magnums), I set the valve lash and then tightened the adjuster nuts. I just did the engine break-in and took the valve covers off to take a look and make sure everything looked good. While I had the valve covers off, I thought I'd recheck the torque on all the head bolts, rocker shaft bolts and adjuster nuts. The head bolts and shaft bolts were fine. When checking the adjuster nuts I found a couple that weren't as tight as the rest. I looked up online to see what the nuts should be torqued to but it seems there are varying opinions on this number. I found anywhere from 18 ft/lbs to 30+. So I set them at 25. The nuts that were tight still clicked the torque wrench at 25 but the ones that weren't quite as tight I had to re-tightened with my torque wrench till they were at 25. As an afterthought, I started wondering if tightening them further may have turned the adjuster in further and changed the valve lash. Being the nuts were tight, just not quite at 25 ft/lbs, do you think my tightening the nuts a little more may have moved the adjuster at all? When torquing them I may have turned the adjuster nut at most another quarter of a turn.
Re: Rocker arm adjuster nut torque [Re: 6PAX] #3177693
09/24/23 09:37 AM
09/24/23 09:37 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I had a jam nut loosen on a new motor, and the adjuster backed out enough to allow the pushrod to drop off the adjuster cup. I was over an hour and a half from home, got a DNF at a race I was involved in and had to get towed home.
Since then I always torque, loosen and re-torque the jam nuts at least 5 times or until the jam nut stops advancing more on re-torque, especially on new rocker arms. Most of the jam nuts seem to invariably turn 1/8th to a 1/4 of a turn more than the first time I torque them as they seat onto the rocker arm body further.
The mini torque wrench from LSM Racing is a great tool for running valve lash.
https://lsmproducts.com/products/tq-100-3
Re: Rocker arm adjuster nut torque [Re: jbc426] #3177737
09/24/23 11:47 AM
09/24/23 11:47 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Not cheap (nothing from LSM is), but a nice tool
This one says "Preset from the factory to 22 ft/lbs, but can be customized from 13 to 28 ft/lbs.", but I don't recall mine being 'adjustable'... maybe an earlier model that was pre-set to non-adjustable 22 ft-lbs
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Rocker arm adjuster nut torque [Re: Brad_Haak] #3177765
09/24/23 12:55 PM
09/24/23 12:55 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Mine is about 3 or 4 years old and is adjustable.
Re: Rocker arm adjuster nut torque [Re: markz528] #3177864
09/24/23 05:52 PM
09/24/23 05:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think you could take the head apart on a 3/8 torque wrench, drill the center for the allen key and reassemble. For much less $$
Re: Rocker arm adjuster nut torque [Re: Stanton] #3177913
09/24/23 09:08 PM
09/24/23 09:08 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Always double-check lash after you think you're done.
Yes, it's possible that cranking the locknut by itself can tighten lash.
Re: Rocker arm adjuster nut torque [Re: topside] #3177918
09/24/23 09:25 PM
09/24/23 09:25 PM
Alberta
440_Offroader Offline
Alberta
iagree
Sometimes adjusters will turn, sometimes they don't, when torquing. Best to double check those clearances.
Re: Rocker arm adjuster nut torque [Re: 6PAX] #3177929
09/24/23 10:19 PM
09/24/23 10:19 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
One of these would be your friend. Think you will love it.
Re: Rocker arm adjuster nut torque [Re: 6PAX] #3177944
09/24/23 11:17 PM
09/24/23 11:17 PM
I use 17 ft. lbs. on 5/16x24 adjusters and 23 ft. lbs. on 7/16x20 size adjusters. I convert the ft. lbs. to inch lbs. and use a good inch lb. torque wrench to tighten the lock nuts.17x12=204 round up or down to 205 or 200, 23x12=276 inch lbs. round off to 275 inch lbs. up
IHTHs
Re: Rocker arm adjuster nut torque [Re: mopar dave] #3177954
09/25/23 01:59 AM
09/25/23 01:59 AM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
Have had one for at least 25 years now. Won’t adjust rockers with out it.
Re: Rocker arm adjuster nut torque [Re: Dabee] #3177979
09/25/23 08:32 AM
09/25/23 08:32 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I like how the tool makes the job easier and is a torque wrench as well. I have several LSM tools and they are all great quality tools.
