Re: Rocker arm adjuster nut torque
[Re: 6PAX]
#3177693
09/24/23 09:37 AM
09/24/23 09:37 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I had a jam nut loosen on a new motor, and the adjuster backed out enough to allow the pushrod to drop off the adjuster cup. I was over an hour and a half from home, got a DNF at a race I was involved in and had to get towed home. Since then I always torque, loosen and re-torque the jam nuts at least 5 times or until the jam nut stops advancing more on re-torque, especially on new rocker arms. Most of the jam nuts seem to invariably turn 1/8th to a 1/4 of a turn more than the first time I torque them as they seat onto the rocker arm body further. The mini torque wrench from LSM Racing is a great tool for running valve lash. https://lsmproducts.com/products/tq-100-3
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#3177737
09/24/23 11:47 AM
09/24/23 11:47 AM
Posts: 1,151 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Not cheap (nothing from LSM is), but a nice tool This one says "Preset from the factory to 22 ft/lbs, but can be customized from 13 to 28 ft/lbs.", but I don't recall mine being 'adjustable'... maybe an earlier model that was pre-set to non-adjustable 22 ft-lbs
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3177765
09/24/23 12:55 PM
09/24/23 12:55 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Not cheap (nothing from LSM is), but a nice tool This one says "Preset from the factory to 22 ft/lbs, but can be customized from 13 to 28 ft/lbs.", but I don't recall mine being 'adjustable'... maybe an earlier model that was pre-set to non-adjustable 22 ft-lbs Mine is about 3 or 4 years old and is adjustable.
[Re: 6PAX]
#3177944
09/24/23 11:17 PM
09/24/23 11:17 PM
Posts: 43,255 Bend,OR USA
Cab_Burge
I use 17 ft. lbs. on 5/16x24 adjusters and 23 ft. lbs. on 7/16x20 size adjusters. I convert the ft. lbs. to inch lbs. and use a good inch lb. torque wrench to tighten the lock nuts.17x12=204 round up or down to 205 or 200, 23x12=276 inch lbs. round off to 275 inch lbs. IHTHs
[Re: mopar dave]
#3177954
09/25/23 01:59 AM
09/25/23 01:59 AM
Posts: 3,455 Dandridge TN
Dabee
Dandridge TN
One of these would be your friend. Think you will love it. Have had one for at least 25 years now. Won’t adjust rockers with out it.
