Going to look at a real clean low mile 86 Reliant K car wagon this morning. Unfortunately, the gears in my head are grinding. I know some people used to do a small block swap but I'm wondering out loud if this would be possible.
Re: Has anyone done a 440 K car swap?
[Re: quickd100]
#3177375 09/23/2308:11 AM09/23/2308:11 AM
as you are going to hear over and over, anything is possible just how much work and money do you want to put into the effort? It sure would be cool when done.
Thank you Kiddart
[Re: Kiddart]
#3177377 09/23/2308:21 AM09/23/2308:21 AM
this morning i did just see a Dodge Shadow with a 440 in it so it can be done. it's a tube chassis but i know it can be done. if you remember Mike Rath(Mr. P-Body) he had a shadow with a small block and he did all the chassis work in his barn with a strut front end. if there was a path to take the strut front end and a good chassis you will be in the clear. I can actually see it in my mind. you have great vision and imagination.
Thank you Kiddart
[Re: Kiddart]
#3177389 09/23/2309:42 AM09/23/2309:42 AM
A friend of mine raced one years ago in the 9.90 super gas class with a throttle stopped Hemi. Mopar gave him a Strattus years later which he had made into a super gas car. The K car sat for years and I even tried selling it for him. Zero interest by anyone in that car by anyone
We I brought it home. It needs an exhaust pipe just ahead of the muffler and a good cleanup. I'll drive it around as is for a while and do some research.
[Re: Kiddart]
#3177577 09/23/2308:19 PM09/23/2308:19 PM
Saw an interesting fab job on a K car. Owner told me any A body front(frame, K member and complete suspension) welded in place of front frame of any of the K cars. His Omni went 10.20's with 440. Somewhat of how they used F/M body front ends on vintage iron for modern suspension. Don't remember the details.
[Re: A/MP]
#3177578 09/23/2308:25 PM09/23/2308:25 PM
pittsburg racer,was that hemi k car you was talking about red
Man it’s been so long since I’ve seen that car. It was white and green or a maroon color I think. Frank Miller, It’s Miller time. I’ll try to find some pictures later
I know who that is. Car was named after a famous beer slogan. Made a few wisecracks about my small block powered car when I bumped into him out in D3. Friend of mine built the Stratus. Haven't seen him in years,
[Re: CMcAllister]
#3178585 09/27/2311:52 AM09/27/2311:52 AM
Had a friend that swapped a small block stroker into a Shadow twenty years ago. Was done nice and it fit entirely under the stock hood. You couldn't really tell. Only give away was the larger rear tires.
[Re: Uberpube]
#3178638 09/27/2302:08 PM09/27/2302:08 PM
