Upper rear shock spacers
#3177537
09/23/23 05:36 PM
09/23/23 05:36 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
I'm in the middle of installing new rear shocks on my cuda. There is a gap between each side of the shock and the shock crossmember. Should there be a spacer to take up any slop or is this ok? The shocks on came with these two inserts, I'm assuming they go on the upper shock bolt? There is still space even with these installed.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Upper rear shock spacers
[Re: stumpy]
#3177746
09/24/23 12:14 PM
09/24/23 12:14 PM
Posts: 19,696 north of coder
moparx
how much space is there ? common washers could be used if needed. a tip to install all these washers without them falling out. tie them to the shock with common sewing thread. two opposite pieces of thread will hold the assembly together while you install the retaining bolt.
[Re: moparx]
#3177823
09/24/23 03:20 PM
09/24/23 03:20 PM
73cuda340
clarks summit pa
how much space is there ? common washers could be used if needed. a tip to install all these washers without them falling out. tie them to the shock with common sewing thread. two opposite pieces of thread will hold the assembly together while you install the retaining bolt. About 3/8" to 1/2" on each side even with the spacers installed on the top bolts
[Re: 73cuda340]
#3177925
09/24/23 10:16 PM
09/24/23 10:16 PM
Posts: 15,565 Omaha Ne
TJP
Omaha Ne
how much space is there ? common washers could be used if needed. a tip to install all these washers without them falling out. tie them to the shock with common sewing thread. two opposite pieces of thread will hold the assembly together while you install the retaining bolt. About 3/8" to 1/2" on each side even with the spacers installed on the top bolts I'm hoping you mean the R and L shock when you say each side Either way the gap needs to be filled. I'd be tempted to send them back myself
[Re: moparx]
#3177996
09/25/23 09:41 AM
09/25/23 09:41 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
how much space is there ? common washers could be used if needed. a tip to install all these washers without them falling out. tie them to the shock with common sewing thread. two opposite pieces of thread will hold the assembly together while you install the retaining bolt. This.... The relatively thin sheetmetal the upper shock mount is made of requires spacers so it won't collapse when the upper bolt is tightened. I use a small stack of the correct size Grade 8 washers on both sides of the shock to avoid deforming the shock cross member. I use tape to hold them in place while I install the bolt.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 73cuda340]
#3178080
09/25/23 01:16 PM
09/25/23 01:16 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
I'm in the middle of installing new rear shocks on my cuda. There is a gap between each side of the shock and the shock crossmember. Should there be a spacer to take up any slop or is this ok? The shocks on came with these two inserts, I'm assuming they go on the upper shock bolt? There is still space even with these installed. Those aren't factory , back then the shock washers looked like the ones in this link https://www.amazon.com/Monroe-P0113...tKUs4IDTX-J6EEBmyeNLdxQWfmxoCFeIQAvD_BwEIf you need more than what is in this picture then the bushings on the shocks are narrower than original and you'll need to take up the space, I'd use grade 8 washers as noted in the post above me.
[Re: TJP]
#3178150
09/25/23 04:57 PM
09/25/23 04:57 PM
73cuda340
clarks summit pa
how much space is there ? common washers could be used if needed. a tip to install all these washers without them falling out. tie them to the shock with common sewing thread. two opposite pieces of thread will hold the assembly together while you install the retaining bolt. About 3/8" to 1/2" on each side even with the spacers installed on the top bolts I'm hoping you mean the R and L shock when you say each side Either way the gap needs to be filled. I'd be tempted to send them back myself Nope, that's on each side of the shock. The shocks are qa1 double adjustables. I called qa1 and they said the same as above, just add washers to take up the space.
[Re: 73cuda340]
#3178235
09/25/23 10:25 PM
09/25/23 10:25 PM
TJP
Omaha Ne
how much space is there ? common washers could be used if needed. a tip to install all these washers without them falling out. tie them to the shock with common sewing thread. two opposite pieces of thread will hold the assembly together while you install the retaining bolt. About 3/8" to 1/2" on each side even with the spacers installed on the top bolts I'm hoping you mean the R and L shock when you say each side Either way the gap needs to be filled. I'd be tempted to send them back myself Nope, that's on each side of the shock. The shocks are qa1 double adjustables. I called qa1 and they said the same as above, just add washers to take up the space. I would tell them to put their shocks where the sun don't shine. Accepting this type of BS condones it and will encourage more slacking on their part as well as others. Doesn't take a lot of effort to program a CNC lathe to spit the correct size spacers out for the application PURE š©š¤¬š IMO. I'm sure they are cheap as well NOT!!!!!
[Re: A39Coronet]
#3178253
09/26/23 12:35 AM
09/26/23 12:35 AM
Posts: 10,241 Someplace you aren't
SomeCarGuy
^agreed. QA1 is supposed to translate to "Quality Assurance #1" ironically Agreed x2. Iām looking at bilsteins right now and they have same exact complaint about rear upper spacer being waaaaayyyy to short. What a bunch of [censored].
I want my fair share
[Re: SomeCarGuy]
#3178286
09/26/23 09:41 AM
09/26/23 09:41 AM
73cuda340
clarks summit pa
Well I bought these shocks about 2 years ago so there's no returning them at this point, I'll just have to use the spacers and washer method. It's very fitting though, considering 99% of the companies dealt with restoring my car from the engine and paint down to the smallest piece of hardware has been nothing but a problem or I've been downright screwed by them. If it's just some spacers, I'll have to deal with it like everything else.
[Re: SomeCarGuy]
#3178493
09/26/23 10:49 PM
09/26/23 10:49 PM
TJP
Omaha Ne
^agreed. QA1 is supposed to translate to "Quality Assurance #1" ironically Agreed x2. Iām looking at bilsteins right now and they have same exact complaint about rear upper spacer being waaaaayyyy to short. What a bunch of [censored]. Welcome to the NEW way of doing things. We no longer count as being worthwhile as the companies are chasing the new era muscle cars. Wouldn't be a bit surprised if they were coming out of the same factory A little googling showed some on other forums coming from ???? Nah, Can't be š² As I Previously stated, Accepting this type of BS condones it and will encourage more slacking on their part as well as others. Doesn't take a lot of effort to program a CNC lathe to spit the correct size spacers out for the application PURE š©š¤¬š IMO.
