Upper rear shock spacers #3177537
09/23/23 04:36 PM
09/23/23 04:36 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I'm in the middle of installing new rear shocks on my cuda. There is a gap between each side of the shock and the shock crossmember. Should there be a spacer to take up any slop or is this ok? The shocks on came with these two inserts, I'm assuming they go on the upper shock bolt? There is still space even with these installed.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Upper rear shock spacers [Re: 73cuda340] #3177636
09/23/23 10:43 PM
09/23/23 10:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
These look like the same spacers on the bottom of the shocks..
Re: Upper rear shock spacers [Re: stumpy] #3177746
09/24/23 11:14 AM
09/24/23 11:14 AM
moparx Offline
moparx  Offline
how much space is there ?
common washers could be used if needed.
a tip to install all these washers without them falling out. tie them to the shock with common sewing thread. two opposite pieces of thread will hold the assembly together while you install the retaining bolt.
beer
Re: Upper rear shock spacers [Re: moparx] #3177797
09/24/23 01:18 PM
09/24/23 01:18 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
I tack glued bibb washers from a garden hose onto those spacers to take up the gap on mine.
Re: Upper rear shock spacers [Re: moparx] #3177823
09/24/23 02:20 PM
09/24/23 02:20 PM
clarks summit pa
clarks summit pa
beer
About 3/8" to 1/2" on each side even with the spacers installed on the top bolts
Re: Upper rear shock spacers [Re: 73cuda340] #3177925
09/24/23 09:16 PM
09/24/23 09:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
I'm hoping you mean the R and L shock when you say each side eek Either way the gap needs to be filled. I'd be tempted to send them back myself twocents beer
Re: Upper rear shock spacers [Re: moparx] #3177996
09/25/23 08:41 AM
09/25/23 08:41 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
beer
This....
The relatively thin sheetmetal the upper shock mount is made of requires spacers so it won't collapse when the upper bolt is tightened. I use a small stack of the correct size Grade 8 washers on both sides of the shock to avoid deforming the shock cross member. I use tape to hold them in place while I install the bolt.
Re: Upper rear shock spacers [Re: 73cuda340] #3178080
09/25/23 12:16 PM
09/25/23 12:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Those aren't factory , back then the shock washers looked like the ones in this link
https://www.amazon.com/Monroe-P0113...tKUs4IDTX-J6EEBmyeNLdxQWfmxoCFeIQAvD_BwE
If you need more than what is in this picture then the bushings on the shocks are narrower than original and you'll need to take up the space, I'd use grade 8 washers as noted in the post above me.
Re: Upper rear shock spacers [Re: TJP] #3178150
09/25/23 03:57 PM
09/25/23 03:57 PM
clarks summit pa
clarks summit pa
beer
Nope, that's on each side of the shock. The shocks are qa1 double adjustables. I called qa1 and they said the same as above, just add washers to take up the space.
Re: Upper rear shock spacers [Re: 73cuda340] #3178169
09/25/23 05:04 PM
09/25/23 05:04 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Literally going through your exact experience now. Crawled under my car Saturday to put my QA1s on and was like "wait, what's going on here". Had to rig it with a bunch of washers but not much choice. Those spacers they provide don't do much.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Upper rear shock spacers [Re: 73cuda340] #3178235
09/25/23 09:25 PM
09/25/23 09:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
I would tell them to put their shocks where the sun don't shine. Accepting this type of BS condones it and will encourage more slacking on their part as well as others. Doesn't take a lot of effort to program a CNC lathe to spit the correct size spacers out for the application PURE šŸ’©šŸ¤¬šŸ‘Ž IMO. I'm sure they are cheap as well NOT!!!!!
Re: Upper rear shock spacers [Re: 73cuda340] #3178238
09/25/23 09:37 PM
09/25/23 09:37 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
^agreed. QA1 is supposed to translate to "Quality Assurance #1" ironically
Re: Upper rear shock spacers [Re: A39Coronet] #3178253
09/25/23 11:35 PM
09/25/23 11:35 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Agreed x2. I’m looking at bilsteins right now and they have same exact complaint about rear upper spacer being waaaaayyyy to short. What a bunch of [censored].
I want my fair share
Re: Upper rear shock spacers [Re: SomeCarGuy] #3178286
09/26/23 08:41 AM
09/26/23 08:41 AM
clarks summit pa
clarks summit pa
Well I bought these shocks about 2 years ago so there's no returning them at this point, I'll just have to use the spacers and washer method. It's very fitting though, considering 99% of the companies dealt with restoring my car from the engine and paint down to the smallest piece of hardware has been nothing but a problem or I've been downright screwed by them. If it's just some spacers, I'll have to deal with it like everything else.
Re: Upper rear shock spacers [Re: 73cuda340] #3178346
09/26/23 11:36 AM
09/26/23 11:36 AM
The original shocks upper steel sleeve extended, protruded, beyond the upper shock eye to help center the shocks in the shock crossmembers up
It sounds like your after market shocks aren't made for Mopar specific installations shruggy work
I would definitely take the time to put some spacers in between the shocks and crossmember so the upper shock bodies can't, won't, move around under rapid acceleration and stopping upwrench
Re: Upper rear shock spacers [Re: SomeCarGuy] #3178493
09/26/23 09:49 PM
09/26/23 09:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Welcome to the NEW way of doing things. We no longer count as being worthwhile as the companies are chasing the new era muscle cars.
Wouldn't be a bit surprised if they were coming out of the same factory whistling A little googling showed some on other forums coming from ???? Nah, Can't be 😲
As I Previously stated,
Quote
