Re: Dual line Milodon oil line routing?
[Re: gregsdart]
#3177473
09/23/23 02:05 PM
09/23/23 02:05 PM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have been battling this off and on since 1981! The extra fittings don't give me concern, just need to be carefull, tighten properly, I will be happy to end up with a system i don't have to eorry about all the time!
[Re: gregsdart]
#3177482
09/23/23 02:23 PM
09/23/23 02:23 PM
Posts: 8,324 fredericksburg,va
cudaman1969
fredericksburg,va
I have been battling this off and on since 1981! The extra fittings don't give me concern, just need to be carefull, tighten properly, I will be happy to end up with a system i don't have to eorry about all the time! That’s the reason I’m not using the curved aluminum tube (afraid it’ll crack). Really only the line to cover needs to be curved up since it goes right into the rotors. On the cover I removed the side hole then moved the top hole forward about 3/4” to get room for engine mount. Once engine is in car (64) I’ll see the best way to route that line to clear headers and mount.
