Brake Upgrade #3177224
09/22/23 03:02 PM
09/22/23 03:02 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Looking to do a brake upgrade on my 52 Dodge B3B. I’m running a front clip off a 1988 Dodge Dakota with the stock Dakota disk brakes. The motor is a Desoto 330 Hemi. I’ve looked at some of the aftermarket brake kits like Powerstop and they don’t offer anything for the Dodge Dakota. Maybe thinking there’s a larger brake setup off a larger vehicle that’s compatible.
Abe Lincoln
Re: Brake Upgrade [Re: dart4forte] #3177308
09/22/23 08:16 PM
09/22/23 08:16 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
People put Viper brakes on 2nd Gen Dakota pickups. Not sure anyone makes anything for an 88 model? Maybe some of the 2nd Gen parts can be installed on your front end?
BTW the Viper parts require large diameter rims as the rotors are bigger. Depending on what size wheels you have the Viper parts may not fit behind them.
Re: Brake Upgrade [Re: Neil] #3177373
09/23/23 08:00 AM
09/23/23 08:00 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
What are you running for rear brakes?
Angry white pureblood male
Re: Brake Upgrade [Re: dart4forte] #3177382
09/23/23 09:02 AM
09/23/23 09:02 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What is your reasoning for considering a brake upgrade?
Re: Brake Upgrade [Re: ruderunner] #3177748
09/24/23 12:21 PM
09/24/23 12:21 PM
Mesa, Arizona
Mesa, Arizona
10” drums, E body rear
Abe Lincoln
Re: Brake Upgrade [Re: jcc] #3177749
09/24/23 12:25 PM
09/24/23 12:25 PM
Mesa, Arizona
Mesa, Arizona
53 B3B with a 330 Desoto Hemi on a 88 Dakota clip. Truck is real nose heavy. Braking from hwy speeds is challanging. Getting a lot of brake fade. One of the mods I’ll do is go to a early Ram MC, more capacity.
Abe Lincoln
Re: Brake Upgrade [Re: dart4forte] #3177871
09/24/23 06:31 PM
09/24/23 06:31 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I was going to suggest better pad material as an option, but looking around it does not appear to be an option.
Re: Brake Upgrade [Re: Sniper] #3177998
09/25/23 09:48 AM
09/25/23 09:48 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Maybe check in with Cass (Dr. Diff) . . . he might have good suggestion for you. . . .
Re: Brake Upgrade [Re: dart4forte] #3178000
09/25/23 09:50 AM
09/25/23 09:50 AM
Mesa, Arizona
Mesa, Arizona
Yeah, not a lot of options
Abe Lincoln
Re: Brake Upgrade [Re: dart4forte] #3205876
01/18/24 01:32 PM
01/18/24 01:32 PM
Green Bay
Andyvh1959 Offline
Andyvh1959  Offline
Green Bay
One thing for certain, the front disc brakes on the 97 to 2002 Dakota, in a word, suck. Crap really, poor feel, dragging/stuck calipers, pad wear/rotor heat/ warpping. I have read the front disc brakes from the 2003 Durango are much improved in all aspects and the parts can be directly mounted to the 97 to 2002 Dakota. So when I prep my 2001 Dakota chassis to go under my 56 Dodge pickup I'll replace the brake system on the front with the 2003 Durango parts. Anyone out there have done this brake upgrade? Anyone have a complete part list needed?
I've read the parts needed are: 2003 Durango rotors-hubs/spindles/calipers/brake pads. Anything else to plan for when I do the upgrade?
My 56 C3-B8 Dakota build
Re: Brake Upgrade [Re: Andyvh1959] #3205902
01/18/24 02:51 PM
01/18/24 02:51 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
I did this swap on my 99. All you need from the donor is the spindles. If the donor parts are good go with those.
03 Dakota use the same setup.
The 03 tie rod ends are slightly different, so if you use the 97-02 parts the toe will be off, but it's easily fixed at alignment time.
It definitely improves braking. BTW the 03 rotors are 11.75" dia.
I just remembered the 03 setup ditches the screw in slider pins. Horrible idea.
