Brake Upgrade
#3177224
09/22/23 03:02 PM
09/22/23 03:02 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Looking to do a brake upgrade on my 52 Dodge B3B. I’m running a front clip off a 1988 Dodge Dakota with the stock Dakota disk brakes. The motor is a Desoto 330 Hemi. I’ve looked at some of the aftermarket brake kits like Powerstop and they don’t offer anything for the Dodge Dakota. Maybe thinking there’s a larger brake setup off a larger vehicle that’s compatible.
Abe Lincoln
Re: Brake Upgrade
[Re: Neil]
#3177373
09/23/23 08:00 AM
09/23/23 08:00 AM
Posts: 5,949 ohio
ruderunner
ohio
What are you running for rear brakes?
Angry white pureblood male
Re: Brake Upgrade
[Re: dart4forte]
#3177382
09/23/23 09:02 AM
09/23/23 09:02 AM
Posts: 22,730 Bitopia
jcc
Bitopia
What is your reasoning for considering a brake upgrade?
Re: Brake Upgrade
[Re: ruderunner]
#3177748
09/24/23 12:21 PM
09/24/23 12:21 PM
dart4forte
Mesa, Arizona
What are you running for rear brakes? 10” drums, E body rear
Abe Lincoln
Re: Brake Upgrade
[Re: jcc]
#3177749
09/24/23 12:25 PM
09/24/23 12:25 PM
dart4forte
Mesa, Arizona
What is your reasoning for considering a brake upgrade? 53 B3B with a 330 Desoto Hemi on a 88 Dakota clip. Truck is real nose heavy. Braking from hwy speeds is challanging. Getting a lot of brake fade. One of the mods I’ll do is go to a early Ram MC, more capacity.
Abe Lincoln
Re: Brake Upgrade
[Re: dart4forte]
#3178000
09/25/23 09:50 AM
09/25/23 09:50 AM
dart4forte
Mesa, Arizona
What is your reasoning for considering a brake upgrade? 53 B3B with a 330 Desoto Hemi on a 88 Dakota clip. Truck is real nose heavy. Braking from hwy speeds is challanging. Getting a lot of brake fade. One of the mods I’ll do is go to a early Ram MC, more capacity. Yeah, not a lot of options
Abe Lincoln
Re: Brake Upgrade
[Re: dart4forte]
#3205876
01/18/24 01:32 PM
01/18/24 01:32 PM
Posts: 215 Green Bay
Andyvh1959
Green Bay
One thing for certain, the front disc brakes on the 97 to 2002 Dakota, in a word, suck. Crap really, poor feel, dragging/stuck calipers, pad wear/rotor heat/ warpping. I have read the front disc brakes from the 2003 Durango are much improved in all aspects and the parts can be directly mounted to the 97 to 2002 Dakota. So when I prep my 2001 Dakota chassis to go under my 56 Dodge pickup I'll replace the brake system on the front with the 2003 Durango parts. Anyone out there have done this brake upgrade? Anyone have a complete part list needed?
I've read the parts needed are: 2003 Durango rotors-hubs/spindles/calipers/brake pads. Anything else to plan for when I do the upgrade?
My 56 C3-B8 Dakota build
Re: Brake Upgrade
[Re: Andyvh1959]
#3205902
01/18/24 02:51 PM
01/18/24 02:51 PM
Posts: 2,742 541 slobovia
A990
541 slobovia
I've read the parts needed are: 2003 Durango rotors-hubs/spindles/calipers/brake pads. Anything else to plan for when I do the upgrade? I did this swap on my 99. All you need from the donor is the spindles. If the donor parts are good go with those. 03 Dakota use the same setup. The 03 tie rod ends are slightly different, so if you use the 97-02 parts the toe will be off, but it's easily fixed at alignment time. It definitely improves braking. BTW the 03 rotors are 11.75" dia. I just remembered the 03 setup ditches the screw in slider pins. Horrible idea.
