Charlie's oil pan #3176282
09/19/23 12:34 PM
09/19/23 12:34 PM
Malvern Pa
500ci barracuda Offline OP
Malvern Pa
Hello everybody I have a question about oil pans and windage trees. I have a Charlie's oil pan and 9 quart was wondering do I have to run a Windows tray with that or the way their pants are built do I need a windage tray
Re: Charlie's oil pan [Re: 500ci barracuda] #3176526
09/19/23 10:07 PM
09/19/23 10:07 PM
Missouri
galen Online content
galen  Online Content
Missouri
The 3 Charlie's pans I have used all had a windage screen that was held in the pan by 5 or 6 bolts. His pan I have now I am using a crank scraper with his screen. If it doesn't have the screen then personally I would use a tray of some type.
Re: Charlie's oil pan [Re: 500ci barracuda] #3176656
09/20/23 12:26 PM
09/20/23 12:26 PM
an8sec70cuda Offline
The Charlie's pan I have has the "tray" built in. Held in w/ allen head bolts.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Charlie's oil pan [Re: 500ci barracuda] #3176675
09/20/23 01:22 PM
09/20/23 01:22 PM
A727Tflite Offline
A727Tflite  Offline
There are critical differences between a tray, screen and scraper. A tray is solid sheet metal. Even if it has some louvres oil can and will bounce back up at the rotating parts, causing drag.
If the oil level is 6” or more from rotating parts then don’t use the tray.
A properly built screen allows the oil to leave the rotating parts and end up in the sump. Some oil remains on the rotating parts.
A scraper peels the oil from the rotating parts where the oil ends up in the sump.
