Re: 69 superbee inner rear window mouldings
[Re: Dante]
#3175879
09/17/23 06:24 PM
09/17/23 06:24 PM
Posts: 985 montreal,quebec,canada
buzz440
Thanks but.... no thanks, this is the garbage set I've already tried to install on the car and all sorts of fitment issues. I thought I had a bad set so I returned them, I was sent another set, same deal....... at this point I thought it was me so I had A Mopar car buddy of mine try to install these, and same issues, the (2) side pieces don't follow the curves at the roof line and if your lucky and get them to clip into place they don't hold on very well and pop off and the corner pieces don't line up with side pieces and vis-versa. Ex; if you clip the corner piece to the lower moulding (the one that is attached to the rear of the package tray) then the other end doesn't line up with the side mouldings. If you try it the other way by clipping the corner piece to the side moulding, then it won't clip to rear lower moulding because the angle is real off. Now, even though my original moulding is damaged, I put everthing back in its place, removed all that plastic bullcrap mouldings and corner pieces and installed my flexible 1 piece vinyl moulding strip, fits great holds great in the corners and each end touches the lower corner piece. Like I mentioned my car came with this moulding and it is a Chrysler part, it's got the penta star and part # starts with 2936 and thats where the gouge has taken off a piece of the vinyl so I can't search by part number but it is the same shape as the crappy plastic ones and because it fits end to end I deem it original to the car so again.... It's this (FLEXIBLE TYPE) 1 piece vinyl moulding strip that I looking for.
Later, BUZZ
[Re: buzz440]
#3176519
09/19/23 09:30 PM
09/19/23 09:30 PM
Posts: 60 N. of New Orleans
493 70 Runner
N. of New Orleans
I have been down this road, I feel your pain. I chose this generic part after purchasing damaged original b body molding on eBay (the spring steel was cut). windlace
[Re: 493 70 Runner]
#3176666
09/20/23 12:51 PM
09/20/23 12:51 PM
buzz440
Thanks, you've answered all of my questions, I'm going to order that trim you suggested install it and call it a day. I've been screwing around with that back glass moulding for way too long. Texture is not a problem, looks pretty close to me. Again, thanks for the info.
Later, BUZZ
