E-body Dana into 71’ b-body for bigger wheels? #3175897
09/17/23 08:40 PM
09/17/23 08:40 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
So I came across a Dana 60 for an e-body and looking to put it into my 1971 Charger. I wanted to run a slightly narrow rearend so I could put bigger wheels in the back. I figure I could remove the stock mounts, add Cass’s (Dr Diff) rear spring relocation kit and make some decent tire space in there. The e-body is about 2in narrower than the -b-body, so I’m sure I can get some big tires under the back. Hope to try for 12in instead of just smashing a 10in wheel back there. Just wondering if someone has done this and if so, how big of a wheel, tires were you able to fit?
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: migsBIG] #3175927
09/17/23 10:07 PM
09/17/23 10:07 PM
AndyF Online content
AndyF  Online Content
Yes that works but you would probably be money ahead to sell the E body Dana to a collector and then buy a Strange S60 that is the correct width for your wheels and tire combination.
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: migsBIG] #3175930
09/17/23 10:23 PM
09/17/23 10:23 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I went the other way, put a B body dana in a E body. I was thinking the E body diff was wider than a B by about 2"? Anyway, with moving the springs some, I got a 10" wheel in there.
Brian
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: '72CudaRacer] #3175951
09/18/23 05:46 AM
09/18/23 05:46 AM
PA
Harry's Taxi 2 Offline
PA
You are correct, the E-body rear is wider than B-body rear. I did the same as you.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: migsBIG] #3175952
09/18/23 05:49 AM
09/18/23 05:49 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
According to the info below the E body axle is only just over 1 1/4" narrower than the '71 and newer B body one. If you could find a pre '71 B body axle you would be almost 3" narrower.
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: Tig] #3175978
09/18/23 09:20 AM
09/18/23 09:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The posters car is a 71 Charger. They are wider than an E body. The E body is wider than a pre 71 B body.
Doug
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: Harry's Taxi 2] #3176017
09/18/23 11:42 AM
09/18/23 11:42 AM
PA
PA
Guess i should have paid attention to the 1971 part
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: Harry's Taxi 2] #3176024
09/18/23 12:10 PM
09/18/23 12:10 PM
central il.
second 70 Offline
second 70  Offline
central il.
The 70-71 B body dana is longer than an ebody and are rare. Less than 500 made. Only came in 440-6 and hemi 4-speed cars. My 70 Cuda had 1 in it when I bought it so I sold it to a member here that needed it for his hemi car and replaced it with a S-60.
If you you're going to go through the trouble of relocating the springs I'd sell the e-body and go with a pre 70 B-body Dana which is shorter and cheaper.
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: AndyF] #3176096
09/18/23 04:42 PM
09/18/23 04:42 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
it's an aftermerket rearend.
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: second 70] #3176097
09/18/23 04:50 PM
09/18/23 04:50 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
You could get dana 60 in 1970/72 440-4bbl cars too. The reason I was asking about this dana was that it was available and would be cheaper by $1100. It's aftermarket with race axles and ready to go. I was under the assumption the 1971 b-body rears were wider than the e-body rears. Was I wrong?
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: migsBIG] #3176119
09/18/23 06:30 PM
09/18/23 06:30 PM
If it is an aftermarket rear end then you need to measure it since it could be any length.
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: AndyF] #3176181
09/18/23 09:41 PM
09/18/23 09:41 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
it's a Strange 60 built for a customers 1971cuda.
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: migsBIG] #3176212
09/18/23 11:34 PM
09/18/23 11:34 PM
Do you know how wide it is? Don't assume that it was made to stock width unless you've measured it.
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: AndyF] #3176218
09/19/23 01:19 AM
09/19/23 01:19 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Strange S60 Complete. I Strange ever made a bad rearend, that would be, well strange. It was left over from a project build.
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: migsBIG] #3176219
09/19/23 01:36 AM
09/19/23 01:36 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
The wheel/tire width will be limited by how much room you have.
Narrower/wider rear end won't help you in that respect. Would just change the offset. (to center whatever wheel/tire combo will fit)
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: INTMD8] #3176221
09/19/23 01:44 AM
09/19/23 01:44 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Thank you, that's what I was originally thinking, but wanted to confirm. Thinking the Dr DIff )Cass) inboard kit would work nicely with this rear.
https://www.doctordiff.com/71-72-b-body-offset-spring-hanger-shackle-kit.html
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: Tig] #3176254
09/19/23 10:28 AM
09/19/23 10:28 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
That shows all 62-70 B body 8-3/4 rears as the same width. Aren't 65-67 narrower? shruggy
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: slantzilla] #3176256
09/19/23 10:35 AM
09/19/23 10:35 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
This will make ya think. One one rig I run a S60 wider then a 72 B body and adjusted the rim offset and its many times more stable feeling then a narrow rear with the same width rims.
STOP POTATO HATE!
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: migsBIG] #3176278
09/19/23 12:17 PM
09/19/23 12:17 PM
central il.
second 70 Offline
second 70  Offline
central il.
No you're right the 71 is longer than an ebody. Hope this chart helps some of the dates aren't 100% right but it does show the longer tubes on a 71. 603222
Re: E-body Dana into 71’ b-body for bigger wheels? [Re: slantzilla] #3176329
09/19/23 02:17 PM
09/19/23 02:17 PM
moparx Online content
moparx  Online Content
i'm almost positive the 65-66 rears are an inch or so narrower than the 68-70 rears.
i know for a fact the 66 rear i installed in my 64 belvedere post car was an inch plus narrower on each side than the original keyed axle rear was. also, i believe the 64 rear is wider than the 62/63 rears, but i don't know by how much.
that chart has been around for years, and has been complained about being wrong for as many years as it has been out there.
beer
