Re: E-body Dana into 71’ b-body for bigger wheels?
[Re: '72CudaRacer]
#3175951
09/18/23 05:46 AM
09/18/23 05:46 AM
Posts: 287 PA
Harry's Taxi 2
PA
You are correct, the E-body rear is wider than B-body rear. I did the same as you.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: migsBIG]
#3175952
09/18/23 05:49 AM
09/18/23 05:49 AM
Posts: 2,923 A shed in England
Tig
A shed in England
According to the info below the E body axle is only just over 1 1/4" narrower than the '71 and newer B body one. If you could find a pre '71 B body axle you would be almost 3" narrower.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Harry's Taxi 2]
#3176017
09/18/23 11:42 AM
09/18/23 11:42 AM
Posts: 287 PA
Harry's Taxi 2
PA
You are correct, the E-body rear is wider than B-body rear. I did the same as you. Guess i should have paid attention to the 1971 part
[Re: AndyF]
#3176096
09/18/23 04:42 PM
09/18/23 04:42 PM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Yes that works but you would probably be money ahead to sell the E body Dana to a collector and then buy a Strange S60 that is the correct width for your wheels and tire combination. it's an aftermerket rearend.
[Re: second 70]
#3176097
09/18/23 04:50 PM
09/18/23 04:50 PM
migsBIG
San Jose,CA
The 70-71 B body dana is longer than an ebody and are rare. Less than 500 made. Only came in 440-6 and hemi 4-speed cars. My 70 Cuda had 1 in it when I bought it so I sold it to a member here that needed it for his hemi car and replaced it with a S-60.
If you you're going to go through the trouble of relocating the springs I'd sell the e-body and go with a pre 70 B-body Dana which is shorter and cheaper. You could get dana 60 in 1970/72 440-4bbl cars too. The reason I was asking about this dana was that it was available and would be cheaper by $1100. It's aftermarket with race axles and ready to go. I was under the assumption the 1971 b-body rears were wider than the e-body rears. Was I wrong?
[Re: migsBIG]
#3176119
09/18/23 06:30 PM
09/18/23 06:30 PM
Posts: 31,037 Oregon
AndyF
Yes that works but you would probably be money ahead to sell the E body Dana to a collector and then buy a Strange S60 that is the correct width for your wheels and tire combination. it's an aftermerket rearend. If it is an aftermarket rear end then you need to measure it since it could be any length.
[Re: AndyF]
#3176181
09/18/23 09:41 PM
09/18/23 09:41 PM
migsBIG
San Jose,CA
Yes that works but you would probably be money ahead to sell the E body Dana to a collector and then buy a Strange S60 that is the correct width for your wheels and tire combination. it's an aftermerket rearend. If it is an aftermarket rear end then you need to measure it since it could be any length. it's a Strange 60 built for a customers 1971cuda.
[Re: migsBIG]
#3176219
09/19/23 01:36 AM
09/19/23 01:36 AM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
The wheel/tire width will be limited by how much room you have.
Narrower/wider rear end won't help you in that respect. Would just change the offset. (to center whatever wheel/tire combo will fit)
[Re: INTMD8]
#3176221
09/19/23 01:44 AM
09/19/23 01:44 AM
migsBIG
San Jose,CA
Thank you, that's what I was originally thinking, but wanted to confirm. Thinking the Dr DIff )Cass) inboard kit would work nicely with this rear. https://www.doctordiff.com/71-72-b-body-offset-spring-hanger-shackle-kit.html
[Re: slantzilla]
#3176256
09/19/23 10:35 AM
09/19/23 10:35 AM
Posts: 9,468 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
This will make ya think. One one rig I run a S60 wider then a 72 B body and adjusted the rim offset and its many times more stable feeling then a narrow rear with the same width rims.
STOP POTATO HATE!
[Re: migsBIG]
#3176278
09/19/23 12:17 PM
09/19/23 12:17 PM
Posts: 1,707 central il.
second 70
central il.
If you you're going to go through the trouble of relocating the springs I'd sell the e-body and go with a pre 70 B-body Dana which is shorter and cheaper. You could get dana 60 in 1970/72 440-4bbl cars too. The reason I was asking about this dana was that it was available and would be cheaper by $1100. It's aftermarket with race axles and ready to go. I was under the assumption the 1971 b-body rears were wider than the e-body rears. Was I wrong? No you're right the 71 is longer than an ebody. Hope this chart helps some of the dates aren't 100% right but it does show the longer tubes on a 71. 603222
[Re: slantzilla]
#3176329
09/19/23 02:17 PM
09/19/23 02:17 PM
Posts: 19,408 north of coder
moparx
According to the info below the E body axle is only just over 1 1/4" narrower than the '71 and newer B body one. If you could find a pre '71 B body axle you would be almost 3" narrower. That shows all 62-70 B body 8-3/4 rears as the same width. Aren't 65-67 narrower? i'm almost positive the 65-66 rears are an inch or so narrower than the 68-70 rears. i know for a fact the 66 rear i installed in my 64 belvedere post car was an inch plus narrower on each side than the original keyed axle rear was. also, i believe the 64 rear is wider than the 62/63 rears, but i don't know by how much. that chart has been around for years, and has been complained about being wrong for as many years as it has been out there.
