Barracuda 1971 and 1970 door latch/lock differences #2436867
01/18/18 03:00 PM
01/18/18 03:00 PM
Alabama
David1971 Offline OP
Alabama
New member here with my first post. The 1971 Barracuda "Keyless Door Locking System" was listed as standard on the 1971 Barracuda. I would like to confirm that this feature was new for 71. A couple of 70 Barracuda owners have told me that in order to lock their doors, they must use the key. If true, can the 1970 door lock assembly be converted to work "keyless" like the 71?
The reason I ask: In the mid-seventies my Autumn Bronze 71 Barracuda was involved in a minor collision. The body shop replaced the drivers door with a 70 Cuda door. Not knowing any better, I always (30+ years) assumed that there was something wrong with the drivers door lock. Just this past year while searching the web, I found factory specs on the 1971 Barracuda where it talked about the "keyless" operation. So now it seems that I have the wrong style mechanism (1970).
If a conversion is not feasible, then I need to find a 71-74 version. So how I would I tell the difference between a 70 and 71-74 latch/lock assembly when searching swap meets?
Thanks,
David
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: David1971] #2437240
01/19/18 12:58 AM
01/19/18 12:58 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Thats very easy..the 70 is very hard to find...71 and up are a dime a dozen....just find a nice one thats not worn out...that 70 latch is rare..
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: David1971] #2437419
01/19/18 12:59 PM
01/19/18 12:59 PM
moparx Offline
moparx  Offline
no help with your problem, but WELCOME aboard ! wave
beer
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: David1971] #2437476
01/19/18 02:31 PM
01/19/18 02:31 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Still looking for a picture for you of the difference..it has an extra lever..like I said, you cant miss it..is the 70 latch in good shape?..I will take it off your hand
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: David1971] #2437488
01/19/18 02:45 PM
01/19/18 02:45 PM
BDW Offline
BDW  Offline
I modded my 70 because it was a pain to have to use the key.
Just use a Dremel with cutoff wheel and cut the end of that extra lever off.
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: David1971] #2438852
01/22/18 03:33 AM
01/22/18 03:33 AM
Castlegar, BC, Canada
That AMC Guy Online content
That AMC Guy  Online Content
Silly question, but on my pre-'74 AMCs, you press the lock button and then you have two choices. Either:
a) with the door open, pull the interior handle - then release. Close the door. Door remains locked.
b) with the door open, hold the exterior paddle OUT and shut the door. Door will remain locked.
Is that not the case with the Barracuda? I remember my '68 New Yorker was pretty much the same. Lock the door, pull the interior handle, close the door.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: That AMC Guy] #2438927
01/22/18 12:06 PM
01/22/18 12:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The 70 only Chrysler/Dodge/Plymouth line up had the feature where the key was required to lock the car from the outside, on the drivers side only
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: David1971] #2440045
01/24/18 03:03 PM
01/24/18 03:03 PM
Alabama
Alabama
Thanks everyone. What a great forum! The amount of knowledge here is incredible! I will not modify the 70 latch since it is a rarity. Thanks AARCONV. I will give you first shot at it if I decide to part with it. I think I may just try to find a complete 71 and up driver's door. The reason being is that the base Barracuda doors do not have the stainless trim along the top edge like the Cuda. The body shop filled those 8 holes with filler. Over the years, most of the filler has fallen out.
Also a big thanks to CNXT for the pictures. When looking at my other 71 base coupe for comparison, I never noticed that other lever.
David
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: DAYCLONA] #3175846
09/17/23 03:31 PM
09/17/23 03:31 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
This does not apply to E-bodies, both doors in 1970 need the key to be locked from the outside.
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: EW1BH27] #3175861
09/17/23 05:07 PM
09/17/23 05:07 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
So if you're sitting the car and you lock the door, someone could walk up at a red light and open the door?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: A39Coronet] #3175869
09/17/23 05:51 PM
09/17/23 05:51 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
If you’re sitting in the car and the lock button (that’s inside the door handle pull cup) is pushed down then the door cannot be opened from the outside.
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: EW1BH27] #3175875
09/17/23 06:13 PM
09/17/23 06:13 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I'm an idiot, reread your original post.
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: A39Coronet] #3175878
09/17/23 06:20 PM
09/17/23 06:20 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
LOL, no you’re not. Sometimes I just scan through posts and miss something. My 1970 has both types of latches, driver side is ‘70 style and passenger side is ‘71+ (the wrong one). That’s why I did some in depth research into this.
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: EW1BH27] #3175882
09/17/23 06:42 PM
09/17/23 06:42 PM
BDW Offline
BDW  Offline
Simpler explanation is the door has to be closed to lock it.
If door is open the lock latch will not push down.
So, you can lock door from inside (when closed), or the key is needed when outside (door closed)
Annoying feature for passenger door, driver has to wait until passenger exits and closes door, and then reach over and push lock button down.
I cut off the tab on passenger latch to get rid of this 70 only feature.
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: BDW] #3175896
09/17/23 08:35 PM
09/17/23 08:35 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
Here is a picture of the difference
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: DAYCLONA] #3175997
09/18/23 10:23 AM
09/18/23 10:23 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
My first car a 69 Charger was they way too.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: moparmarks] #3176008
09/18/23 11:21 AM
09/18/23 11:21 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Dodge Darts from 67-72 were like that too, I actually liked that you had to lock the car with the key, I never locked my keys in the car! lock
JB Rhinehart, Realist
A-Body's RULE!
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: EW1BH27] #3176066
09/18/23 02:44 PM
09/18/23 02:44 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
If you are in the car, you can lock the doors from the inside. But if I recall on my 70 Challenger, once you opened the door, the lock lever could not be depressed. You had to close the door and lock it with the key.
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: 318 Stroker] #3176270
09/19/23 12:06 PM
09/19/23 12:06 PM
central il.
second 70 Offline
second 70  Offline
central il.
If I remember correctly on a 70 if you lift up the outside door handle you can lock the door with inside lock but you must hold up on outside handle until door closes.
Re: Barracuda 1971 and 1970 door latch/lock differences [Re: second 70] #3176578
09/20/23 08:55 AM
09/20/23 08:55 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
I just came in from the garage and tried that on my driver's door with a '70 latch - It didn't work
FWIW, on another forum I looked like an idiot for second guessing myself due to the statement " on the driver's side only" . Since no one challenged that or checked into it I doubted myself . See, my passenger door has the wrong latch, and I knew that, but reading that previous unproven comment in this thread got me all messed up.
