Re: Barracuda 1971 and 1970 door latch/lock differences
[Re: David1971]
#2437488
01/19/18 02:45 PM
01/19/18 02:45 PM
Posts: 4,750 Florida
BDW
I modded my 70 because it was a pain to have to use the key. Just use a Dremel with cutoff wheel and cut the end of that extra lever off.
[Re: David1971]
#2438852
01/22/18 03:33 AM
01/22/18 03:33 AM
Posts: 4,806 Castlegar, BC, Canada
That AMC Guy
Silly question, but on my pre-'74 AMCs, you press the lock button and then you have two choices. Either:
a) with the door open, pull the interior handle - then release. Close the door. Door remains locked.
b) with the door open, hold the exterior paddle OUT and shut the door. Door will remain locked.
Is that not the case with the Barracuda? I remember my '68 New Yorker was pretty much the same. Lock the door, pull the interior handle, close the door.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: That AMC Guy]
#2438927
01/22/18 12:06 PM
01/22/18 12:06 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Is that not the case with the Barracuda? I remember my '68 New Yorker was pretty much the same. Lock the door, pull the interior handle, close the door. The 70 only Chrysler/Dodge/Plymouth line up had the feature where the key was required to lock the car from the outside, on the drivers side only
[Re: DAYCLONA]
#3175846
09/17/23 03:31 PM
09/17/23 03:31 PM
Posts: 147 Canada
EW1BH27
Canada
The 70 only Chrysler/Dodge/Plymouth line up had the feature where the key was required to lock the car from the outside, on the drivers side only This does not apply to E-bodies, both doors in 1970 need the key to be locked from the outside.
[Re: EW1BH27]
#3175861
09/17/23 05:07 PM
09/17/23 05:07 PM
Posts: 1,115 Usa
A39Coronet
Usa
The 70 only Chrysler/Dodge/Plymouth line up had the feature where the key was required to lock the car from the outside, on the drivers side only This does not apply to E-bodies, both doors in 1970 need the key to be locked from the outside. So if you're sitting the car and you lock the door, someone could walk up at a red light and open the door?
[Re: EW1BH27]
#3175875
09/17/23 06:13 PM
09/17/23 06:13 PM
Posts: 1,115 Usa
A39Coronet
Usa
If you’re sitting in the car and the lock button (that’s inside the door handle pull cup) is pushed down then the door cannot be opened from the outside. I'm an idiot, reread your original post.
[Re: DAYCLONA]
#3175997
09/18/23 10:23 AM
09/18/23 10:23 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Is that not the case with the Barracuda? I remember my '68 New Yorker was pretty much the same. Lock the door, pull the interior handle, close the door. The 70 only Chrysler/Dodge/Plymouth line up had the feature where the key was required to lock the car from the outside, on the drivers side only My first car a 69 Charger was they way too.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: EW1BH27]
#3176066
09/18/23 02:44 PM
09/18/23 02:44 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
If you’re sitting in the car and the lock button (that’s inside the door handle pull cup) is pushed down then the door cannot be opened from the outside. If you are in the car, you can lock the doors from the inside. But if I recall on my 70 Challenger, once you opened the door, the lock lever could not be depressed. You had to close the door and lock it with the key.
[Re: second 70]
#3176578
09/20/23 08:55 AM
09/20/23 08:55 AM
Posts: 147 Canada
EW1BH27
Canada
If I remember correctly on a 70 if you lift up the outside door handle you can lock the door with inside lock but you must hold up on outside handle until door closes. I just came in from the garage and tried that on my driver's door with a '70 latch - It didn't workFWIW, on another forum I looked like an idiot for second guessing myself due to the statement " on the driver's side only" . Since no one challenged that or checked into it I doubted myself . See, my passenger door has the wrong latch, and I knew that, but reading that previous unproven comment in this thread got me all messed up.
