FIBERGLASS radial tires. Compatible w STEEL belt radials?
#3175656
09/16/23 02:27 PM
09/16/23 02:27 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Not BIAS ply but Fiberglass belted radial tires. I have some Pro street Hoosier 29x15x15 rear tires. They are steel belted radials. I would like 28" tall skinny front runners and Mickey Thompson makes them...But...... their Sportsman SR tires (The flame pattern tread) are actually fiberglass radials. Can I safely run Fiberglas radials up front with steel radials in the rear? Hoosier front runners only go to 26." My second option is an all season 205 /75 R15 on a 5" wide wheel but I really want that skinny front runner look. Truck has no significant power (95 Dakota with stock 318) and wont for a long time.
Keep old mopars alive.
Re: FIBERGLASS radial tires. Compatible w STEEL belt radials?
[Re: 2boltmain]
#3175671
09/16/23 03:10 PM
09/16/23 03:10 PM
Posts: 22,696 Bitopia
jcc
Bitopia
IMO, in your current combination, any difference/effect from material construction would be nearly imperceivable.
[Re: jcc]
#3175675
09/16/23 03:37 PM
09/16/23 03:37 PM
Posts: 11,375 NJ
rdrnr6970
Your #1 source for current events
NJ
No I wouldn't mix them together,not safe.
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
[Re: stumpy]
#3175715
09/16/23 08:00 PM
09/16/23 08:00 PM
Posts: 11,375 NJ
rdrnr6970
NJ
I thought I drove this mix on my 70 coronet when I had to change out a flat tire ,the car drove screwy,and I friend told me not to mix the tires like that, of course it was years ago.
[Re: 2boltmain]
#3175720
09/16/23 08:34 PM
09/16/23 08:34 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
They're fine together. The material of the belt isn't nearly as important as the construction.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#3175757
09/16/23 11:51 PM
09/16/23 11:51 PM
Posts: 4,945 WI
Dcuda69
WI
They're fine together. The material of the belt isn't nearly as important as the construction. This guy gets it. A radial tire is a radial tire. I wouldn't mix them on an axle but front/rear...no problem.
[Re: Dcuda69]
#3175766
09/17/23 07:09 AM
09/17/23 07:09 AM
Posts: 5,823 ohio
ruderunner
ohio
Yep. Mixing bias and radials is an issue. If one must, it's recommended to have the bias on front.
Angry white pureblood male
[Re: ruderunner]
#3175780
09/17/23 09:44 AM
09/17/23 09:44 AM
2boltmain
Holland MI Ottawa
Ok thank you. I didn't go with the Mickey Thompson rear tires because I don't care for the flame tread pattern. Looks very 2001ish. I don't mind it on the front though. I ASSUMED all belted construction was steel. I didn't know the MT tires were fiberglass belted. Heard a rumor and then actually had to search a lot online to see they're fiberglass. But The MT tires are great quality and safe-- again I just didn't want that pattern on the rear.
[Re: 2boltmain]
#3175785
09/17/23 10:37 AM
09/17/23 10:37 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Construction differences are more pronounced and more important than material differences. All tires are belted, whether it is bias belted or radial belted. The belts are what's under the rubber that determine all the ride and load characteristics.
Materials for radials can be steel, polyester, fiberglass, Twaron, Kevlar, or combinations of these.
Mixing of bias and radial on a car does create different feel because of the radials tendency to be more compliant while the bias ply tends to be more rigid. This can create conflicting feel and reaction that can make the car feel different. Mixing them won't automatically make your car burst into flames and if you understand the handling differences, you can adjust driving technique. However, for most of us, its easier to simply put compatible tires on all four corners.
I don't doubt that the old Polyglas tires, the BFG belted TA and radial TA , Pontiac's radial tuned suspension of the mid 70s, and all the warnings of mixing tire construction when we were younger has created some fuzzy memories for some of us.
[Re: Neil]
#3176041
09/18/23 01:12 PM
09/18/23 01:12 PM
2boltmain
Holland MI Ottawa
Hoosier makes radial pro street front tires also if you still are shopping options. True but only 26" tall. I want 27" to 28"
