Re: Rear gear ratio question
[Re: B1MAXX]
#3175104
09/14/23 08:03 AM
09/14/23 08:03 AM
Posts: 26,012 United Socialist States of Ame...
tboomer
I think some of this has to do with the converter. My belvedere has 3:23 (I put them in there). 255/60's and an old Banana converter and it is also 2800 at 60mph. That could be. It's pretty quick for a go kart motor!
[Re: Streetwize]
#3175119
09/14/23 08:53 AM
09/14/23 08:53 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
I don't recall a 3.73 being offered, maybe it's a 3.91 though.
It never was an offered ratio by Chrysler back in the day . I don't think it's 3.91 , My dart has that gear with a 26" tire , 4 speed and it buzzes higher than that .
[Re: tboomer]
#3175204
09/14/23 05:04 PM
09/14/23 05:04 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
[Re: JohnRR]
#3175205
09/14/23 05:10 PM
09/14/23 05:10 PM
Cab_Burge
It never was an offered ratio by Chrysler back in the day . I don't think it's 3.91 , My dart has that gear with a 26" tire , 4 speed and it buzzes higher than that . You sir are wrong on this I bought a 1960 Dodge Phoenix in 1967 that had that ratio in it stock, saw the same ratio in a 1957 Plymouth Savoy six cylinder stick shift later also, both cars had not been messed with back then, they were stock
[Re: Cab_Burge]
#3175336
09/15/23 11:03 AM
09/15/23 11:03 AM
JohnRR
It never was an offered ratio by Chrysler back in the day . I don't think it's 3.91 , My dart has that gear with a 26" tire , 4 speed and it buzzes higher than that . You sir are wrong on this I bought a 1960 Dodge Phoenix in 1967 that had that ratio in it stock, saw the same ratio in a 1957 Plymouth Savoy six cylinder stick shift later also, both cars had not been messed with back then, they were stock I knew some old fart was going to come in and say that , I should have said ... that ratio was not offered in 1969 in passenger cars .... better ???
[Re: StrkrDart69]
#3175555
09/16/23 09:00 AM
09/16/23 09:00 AM
JohnRR
Why would anybody even guess with calculations etc. I do not get it. Jack car up, count drive shaft revolutions compared to tire revolutions. Done. MPH vs RPM vs Tire size........ Really. It amazes me how many people do a gear change but do not change trans speedo gear. That could be way off. What happened to keep it simple? You must be new to the internet ?...
[Re: Streetwize]
#3175566
09/16/23 09:26 AM
09/16/23 09:26 AM
Posts: 22,732 Bitopia
jcc
Bitopia
Might be 3.23 or it could be 3.55. there's slip in the converter so it's engine is always going to turn higher than a 1:1 to the tail shaft like a clutch car.
I don't recall a 3.73 being offered, maybe it's a 3.91 though. I may be alone in this aspect, but 3.73 is a rather rare ratio in the first place.
