Re: Rear gear ratio question [Re: Dcuda69] #3175098
09/14/23 07:52 AM
09/14/23 07:52 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I think some of this has to do with the converter. My belvedere has 3:23 (I put them in there). 255/60's and an old Banana converter and it is also 2800 at 60mph.
Re: Rear gear ratio question [Re: B1MAXX] #3175104
09/14/23 08:03 AM
09/14/23 08:03 AM
tboomer Offline OP
tboomer  Offline OP
That could be. It's pretty quick for a go kart motor! laugh2
Re: Rear gear ratio question [Re: tboomer] #3175116
09/14/23 08:46 AM
09/14/23 08:46 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Might be 3.23 or it could be 3.55. there's slip in the converter so it's engine is always going to turn higher than a 1:1 to the tail shaft like a clutch car.
I don't recall a 3.73 being offered, maybe it's a 3.91 though.
WIZE
In Car:
Re: Rear gear ratio question [Re: Streetwize] #3175119
09/14/23 08:53 AM
09/14/23 08:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It never was an offered ratio by Chrysler back in the day . I don't think it's 3.91 , My dart has that gear with a 26" tire , 4 speed and it buzzes higher than that .
Re: Rear gear ratio question [Re: tboomer] #3175204
09/14/23 05:04 PM
09/14/23 05:04 PM
The easiest way to find out quickly what ratio you have without removing the third member is to jack the car up on jackstands so you can crawl under it and mark the driveshaft rear pinion yoke and the third member so you can count the drive shaft revolutions when rotating one of the rear tires one revolution wrench up If it has a posi unit or spool, and the drive shaft rotates 2 3/4 turns it has 2:76 gears, if it rotates almost 3 complete revolutions it has 2.92 gears, 3 1/4 revolutions 3.23 and so on wrenchscope up
If it has a non posi rear end you need to lock up one tire so it won't move and then rotate the other tire two complete revolutions of the other tire and count the driveshaft revolutions to get it correct due to the spide(corrected up whistling)r gears having to do their thing properly on rotating with the driveshaft with the other wheel being held up scope up shruggy
Thanks for pointing out my bad spelling blush up
Re: Rear gear ratio question [Re: JohnRR] #3175205
09/14/23 05:10 PM
09/14/23 05:10 PM
You sir are wrong on this tsk
I bought a 1960 Dodge Phoenix in 1967 that had that ratio in it stock, saw the same ratio in a 1957 Plymouth Savoy six cylinder stick shift later also, both cars had not been messed with back then, they were stock upshruggy
Re: Rear gear ratio question [Re: Cab_Burge] #3175246
09/14/23 08:40 PM
09/14/23 08:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If it has a non posi rear end you need to lock up one tire so it won't move and then rotate the other tire two complete revolutions of the other tire and count the driveshaft revolutions to get it correct due to the speeder Spider gears having to do their thing properly on rotating with the driveshaft with the other wheel being held up scope up shruggy
Fixedf it for ya wink beer
Re: Rear gear ratio question [Re: Cab_Burge] #3175247
09/14/23 08:42 PM
09/14/23 08:42 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I think he was thinking 62 and up wink beer
Re: Rear gear ratio question [Re: tboomer] #3175295
09/15/23 07:52 AM
09/15/23 07:52 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
the small diameter borescope cameras are so good and inexpensive that
counting the teeth of the pinion and ring gear may involve the least sweat and effort
- plus an unexpected problem might be spotted early
I would have never guessed that “prime numbers” of gear teeth are much preferred for better durability and lower whine noise.
Re: Rear gear ratio question [Re: Cab_Burge] #3175336
09/15/23 11:03 AM
09/15/23 11:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I knew some old fart was going to come in and say that , I should have said ... that ratio was not offered in 1969 in passenger cars .... better ??? wink
Re: Rear gear ratio question [Re: TJP] #3175337
09/15/23 11:05 AM
09/15/23 11:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
More like the muscle car era and in passenger cars ... but yes post 62 , I should have been clearer
Re: Rear gear ratio question [Re: JohnRR] #3175354
09/15/23 12:12 PM
09/15/23 12:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
That's OK John, we all make statements that can be taken out of context. BTW, I fixed his "SPEEDER" gears a couple of comments earlier up
beer beer to both for your contributions to the "BORED" up
Re: Rear gear ratio question [Re: tboomer] #3175367
09/15/23 12:25 PM
09/15/23 12:25 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Why would anybody even guess with calculations etc. I do not get it. Jack car up, count drive shaft revolutions compared to tire revolutions. Done. MPH vs RPM vs Tire size........ Really. It amazes me how many people do a gear change but do not change trans speedo gear. That could be way off. What happened to keep it simple?
Re: Rear gear ratio question [Re: StrkrDart69] #3175555
09/16/23 09:00 AM
09/16/23 09:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You must be new to the internet ?... laugh2
Re: Rear gear ratio question [Re: Streetwize] #3175566
09/16/23 09:26 AM
09/16/23 09:26 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I may be alone in this aspect, but 3.73 is a rather rare ratio in the first place.
