Weird A/C Issue #3172284
09/02/23 11:42 AM
09/02/23 11:42 AM
Sunshine State
Crosshairs Offline OP
Sunshine State
1989 Dodge Dakota 3.9 2WD. The A/C blows nice and cold (48) on all fan speeds except HIGH (the clutch turns off). Once I lower the fan speed, the clutch kicks back on and everything is cool again!
Re: Weird A/C Issue [Re: Crosshairs] #3172288
09/02/23 11:53 AM
09/02/23 11:53 AM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Blower resistor
Re: Weird A/C Issue [Re: 1969RR] #3172300
09/02/23 12:18 PM
09/02/23 12:18 PM
Sunshine State
Sunshine State
Originally Posted by 1969RR
Blower resistor
I thought a bad resistor only allowed the fan to blow at one speed.
Re: Weird A/C Issue [Re: Crosshairs] #3172321
09/02/23 01:36 PM
09/02/23 01:36 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Blower resistor
Correct and that speed is
wait for it
High
And it doesn't effect the clutch, unless the AC line pressure gets too high, but that would the the pressure switch kicking in.
Re: Weird A/C Issue [Re: Sniper] #3172341
09/02/23 02:09 PM
09/02/23 02:09 PM
Sunshine State
Sunshine State
Blower resistor
wait for it
High
Still don't understand what the blower speed has to do with the clutch! What am I missing?
Re: Weird A/C Issue [Re: Crosshairs] #3172468
09/02/23 10:38 PM
09/02/23 10:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Blower resistor
wait for it
High
I'm thinking the line pressure shruggy
Re: Weird A/C Issue [Re: TJP] #3172473
09/02/23 11:05 PM
09/02/23 11:05 PM
Sunshine State
Sunshine State
So the high blower speed causes increased line pressure that activates the clutch cutoff?? Do I have that right? I mean a resistor is dirt cheap, I just want to understand it too!
Re: Weird A/C Issue [Re: Crosshairs] #3172524
09/03/23 10:00 AM
09/03/23 10:00 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Lack of the fan working might be causing the line pressure to rise triggering the high pressure shut off, but it would not be instantaneous.
You probably have a short dropping power to the clutch circuit when you switch to high fan speed. Unplug the fan and see what happens when you put it in high.
Re: Weird A/C Issue [Re: Crosshairs] #3174418
09/11/23 02:05 PM
09/11/23 02:05 PM
Sunshine State
Sunshine State
**************It seems it was the blower resistor************************* Thanks
Re: Weird A/C Issue [Re: Crosshairs] #3174419
09/11/23 02:10 PM
09/11/23 02:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Weird A/C Issue [Re: TJP] #3174929
09/13/23 01:15 PM
09/13/23 01:15 PM
moparx Offline
moparx  Offline
glad it was a simple fix !
beer
