Re: Rear gear ratio question
[Re: tboomer]
#3174771
09/12/23 06:41 PM
09/12/23 06:41 PM
Posts: 15,855 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
IDK but with those size wheels/tires and a three speed non lockup that seems like a 3.23 to me.
Facts are stubborn things.
[Re: NITROUSN]
#3174870
09/13/23 08:07 AM
09/13/23 08:07 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
doing the math, a 215/70R14 would have 780 revolutions per mile. (rev/mi)..50 MPH is .833 miles/min. so the tire is rotating 650 rev/min. 2500 RPM for the engine / 650 RPM for the tire works out to 3.84:1. depending on converter slip (usually 3-5%) that looks like a 3.73... depends on how "about 2500 RPM you are. ~2400, it's probably a 3.55 assuming 4% converter slip....
[Re: tboomer]
#3174892
09/13/23 09:43 AM
09/13/23 09:43 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Thanks guys...I think I have another issue with the kickdown linkage. The guy that replaced the carb didn't set it...Any pics as to what it should look like? Just to make sure we're not going down a rabbit hole, this is a 340?
[Re: tboomer]
#3174921
09/13/23 12:50 PM
09/13/23 12:50 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Thanks guys! Barry...I do not know any of the answers for you. I have things written down somewhere and it's quite possible to be a 3.73 gear in the GTS 340. I will look at my tag later. Ted the axle ratio was never called out on the fendertag of that year/ plant build Dart , the only way you are going to find it is if you have the broadcast sheet. You are going to have to get dirty to figure out what the car has, and which part is incorrect .
[Re: tboomer]
#3174940
09/13/23 01:45 PM
09/13/23 01:45 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Thanks guys...I think I have another issue with the kickdown linkage. The guy that replaced the carb didn't set it...Any pics as to what it should look like? If it's an aftermarket carb, be sure you have the correct Mopar throttle lever extension.
