Rear gear ratio question #3174750
09/12/23 05:05 PM
09/12/23 05:05 PM
tboomer Offline OP
tboomer  Offline OP
Last Sunday my wife and I took the Dart GTS about 30 miles to a local car show. I thought it was supposed to have 3:23 gears in the 8.75 but at just over 50 mph my tach is turning 2500 rpms...The car has 215-70-R14 tires on it. It has a 727 transmission. What does it have for rear gears? Thanks! Ted up
Re: Rear gear ratio question [Re: tboomer] #3174754
09/12/23 05:18 PM
09/12/23 05:18 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
3.73 gears by my math drive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Rear gear ratio question [Re: tboomer] #3174755
09/12/23 05:20 PM
09/12/23 05:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Tachometers are not always correct.
Speedometers are also not always correct, but if you have a GPS like a Garmin you can double check it.
What is the speedometer gear count?
What is the tire diameter?
Those would help.
Or you can jack it up & spin a rear wheel while counting driveshaft revolutions.
Re: Rear gear ratio question [Re: Alaskan_TA] #3174756
09/12/23 05:25 PM
09/12/23 05:25 PM
tboomer Offline OP
tboomer  Offline OP
Thanks guys! Barry...I do not know any of the answers for you. I have things written down somewhere and it's quite possible to be a 3.73 gear in the GTS 340. I will look at my tag later. up
Re: Rear gear ratio question [Re: tboomer] #3174761
09/12/23 05:33 PM
09/12/23 05:33 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
3.73 was not available, has the car been modified?
What year is the car? Here is a link for 1969 Dart ratios as one possible example;
www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1969/69_Dart0028.jpg
Re: Rear gear ratio question [Re: Alaskan_TA] #3174765
09/12/23 05:58 PM
09/12/23 05:58 PM
tboomer Offline OP
tboomer  Offline OP
You are correct Barry! I think it has been modified. wave
Re: Rear gear ratio question [Re: tboomer] #3174771
09/12/23 06:41 PM
09/12/23 06:41 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
IDK but with those size wheels/tires and a three speed non lockup that seems like a 3.23 to me.
Facts are stubborn things.
Re: Rear gear ratio question [Re: larrymopar360] #3174788
09/12/23 07:38 PM
09/12/23 07:38 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Here is the info I found for that size of tire for reference.
215/70R14 tires have a diameter of 25.9", a section width of 8.5", and a wheel diameter of 14". The circumference is 81.2" and they have 781 revolutions per mile.
Re: Rear gear ratio question [Re: Neil] #3174798
09/12/23 08:02 PM
09/12/23 08:02 PM
tboomer Offline OP
tboomer  Offline OP
Thanks Larry and Dr.Neil!
Re: Rear gear ratio question [Re: tboomer] #3174805
09/12/23 08:15 PM
09/12/23 08:15 PM
N
NITROUSN Offline
NITROUSN  Offline
N
By those numbers 3:23 sounds about right at 2,500. 3:91 would be about 3,050 and 3:55 would be 2,775.
Re: Rear gear ratio question [Re: NITROUSN] #3174870
09/13/23 08:07 AM
09/13/23 08:07 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
doing the math, a 215/70R14 would have 780 revolutions per mile. (rev/mi)..50 MPH is .833 miles/min. so the tire is rotating 650 rev/min. 2500 RPM for the engine / 650 RPM for the tire works out to 3.84:1. depending on converter slip (usually 3-5%) that looks like a 3.73... depends on how "about 2500 RPM you are. ~2400, it's probably a 3.55 assuming 4% converter slip....
2017 Grand Cherokee Overland
Re: Rear gear ratio question [Re: patrick] #3174877
09/13/23 08:46 AM
09/13/23 08:46 AM
VA
dragon slayer Offline
VA
Just because speedometer says 50, doesn't mean that is the speed, if the gear in the transmission is not correct. Normally you know tire size and gear ratio. You use the SVM chart and make sure your speedometer gear is the size the chart says. Then your speedometer would be accurate.
You are working backwards and may have 2 different variables. Gear ratio and trans speedo gear. So go drive by a speed sensor set up around a school or road in your area. If the speedometer reads accurate then you can calculate the gear ratio.
Re: Rear gear ratio question [Re: dragon slayer] #3174883
09/13/23 09:07 AM
09/13/23 09:07 AM
tboomer Offline OP
tboomer  Offline OP
Thanks guys...I think I have another issue with the kickdown linkage. The guy that replaced the carb didn't set it...Any pics as to what it should look like? wave
Re: Rear gear ratio question [Re: tboomer] #3174892
09/13/23 09:43 AM
09/13/23 09:43 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Just to make sure we're not going down a rabbit hole, this is a 340?
Re: Rear gear ratio question [Re: 6PakBee] #3174906
09/13/23 11:21 AM
09/13/23 11:21 AM
tboomer Offline OP
tboomer  Offline OP
Yes. 340 auto on the floor. up
Re: Rear gear ratio question [Re: tboomer] #3174909
09/13/23 11:46 AM
09/13/23 11:46 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: Rear gear ratio question [Re: tboomer] #3174921
09/13/23 12:50 PM
09/13/23 12:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ted the axle ratio was never called out on the fendertag of that year/ plant build Dart , the only way you are going to find it is if you have the broadcast sheet. You are going to have to get dirty to figure out what the car has, and which part is incorrect .
Re: Rear gear ratio question [Re: tboomer] #3174940
09/13/23 01:45 PM
09/13/23 01:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it's an aftermarket carb, be sure you have the correct Mopar throttle lever extension.
Re: Rear gear ratio question [Re: John_Kunkel] #3174953
09/13/23 03:06 PM
09/13/23 03:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Two other ways to know:
1. If the rear axle's never been fooled with, there may be a tag on it with the gear ratio called out; also might be a Sure Grip tag.
2. No matter what, counting how many revolutions of the driveshaft vs a rear tire will give you the ratio.
2500 @ approx 50 could well be 3.23s, but my current comparison is a 4-speed car with a 28-ish-inch tire (275/60R15); that's about 55 in my car.
I can't say that my speedo is dead accurate, not any of them for that matter.
Re: Rear gear ratio question [Re: topside] #3175047
09/13/23 09:20 PM
09/13/23 09:20 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
My setup w/a 26.5" tall(255/60-15) and 3:73/4spd is 2800ish at 60 mph.
