Re: Can you use a new stock time chain with Edelbrock Cam?
[Re: dvw]
#3173846
09/08/23 07:03 PM
09/08/23 07:03 PM
Posts: 6,358 nowhere
Sniper
nowhere
You know what I find interesting. Is how would someone know if any part installed in their engine is worn out in 6 months? And secondly how sloppy is to sloppy? Chains tend to loosen up and function just fine. If some here saw some bracket engines that have been together for years and 1000's of passes they'd have a heart attact. It's amazing what you can get away with. Doug I find it interesting that you haven't looked at the service manual. It tells you how much is too much slop. I suggest you look it up.
[Re: Sniper]
#3173902
09/08/23 10:56 PM
09/08/23 10:56 PM
Posts: 497 Partridge, KY
Hoop
Partridge, KY
Wear I'm trying to decide what to go with, I got a new stock timing chain all so wear I started to go with stock cam or do I got to go with a double timing chain with the edelbrock cam???
[Re: Neil]
#3174965
09/13/23 03:32 PM
09/13/23 03:32 PM
Posts: 9,621 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Folks would be amazed what stamped steel rockers can handle. When 16 and before the internet was here to tell me how wrong I was the mopar 508/292 with adjustable push rods ran all summer in the local street bracket class. I wondered why it would break up over 7200. ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) OP.... you must have money to blow because your making something so so simple into something so difficult and costly, but its your money. $92 for a chain set no better then the $50 BUT it has three keyways which means nothing if your not going to degree it. Same thing as the edelgobroke but 1/2 the cost. https://www.ebay.com/itm/386114754231? Here is the good quality billet thats great for any street/bracket..... SA Billet for same cost as the edlejunk. https://www.ebay.com/itm/204142235932?
STOP POTATO HATE!
[Re: Hoop]
#3174970
09/13/23 03:39 PM
09/13/23 03:39 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Can you use a new stock time chain with Edelbrock Cam? Yes. Not much else to it, really ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
Rich H.
Esse Quam Videri
