Re: Can you use a new stock time chain with Edelbrock Cam? [Re: dvw] #3173821
09/08/23 04:35 PM
09/08/23 04:35 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I think they stretch a lot more than people think at first and then the rate of stretch tapers off.
Bicycle chains behave that way for me. Install and readjust after putting some miles on them to take the initial break-in slack out and then you don't have to do it as much.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Neil] #3173830
09/08/23 05:21 PM
09/08/23 05:21 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Baking the chain in oil reduces the initial chain stretch...
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: NITROUSN] #3173831
09/08/23 05:27 PM
09/08/23 05:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted by NITROUSN
Originally Posted by Hoop
Well, I all ready got a new HEAVY DUTY DOUBLE ROLLER TIMING SET off ebay because I was going to go with a stock cam, but then I was having a had time getting ahold of one, keep getting out of stock & refunded, so I order the edelbrock one from the auto parts, then I read this on jegs! "Do not use late model timing chain and gear sets that are designed for emission-controlled engines. They are machined in a retarded position and are not recommended for this camshaft installation. Use Performer-Link Timing Chain Gear Set 350-7803 or similar set."... This is the one I got off eBay, so I'm wondering should I use it or get the edelbrock one? https://www.ebay.com/itm/133134084872
You should degree every one. I trust none.
iagree If you don't know how to do that and don't have the proper tools to degree the cam, get help or have someone who knows how to degree them properly do that for you wrench up You won't be sorry for getting it (the new cam) installed properly, trust me on that up
Some the new timing sets have the dot on the cam gear between teeth, not directly under one or the other puke whiney That can make the difference of having the cam installed properly or being retarded 12 degrees tskscope panic
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: dvw] #3173846
09/08/23 07:03 PM
09/08/23 07:03 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by dvw
You know what I find interesting. Is how would someone know if any part installed in their engine is worn out in 6 months? And secondly how sloppy is to sloppy? Chains tend to loosen up and function just fine. If some here saw some bracket engines that have been together for years and 1000's of passes they'd have a heart attact. It's amazing what you can get away with.
Doug
I find it interesting that you haven't looked at the service manual. It tells you how much is too much slop.
I suggest you look it up.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Sniper] #3173902
09/08/23 10:56 PM
09/08/23 10:56 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Wear I'm trying to decide what to go with, I got a new stock timing chain all so wear I started to go with stock cam or do I got to go with a double timing chain with the edelbrock cam???
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Hoop] #3173941
09/09/23 08:32 AM
09/09/23 08:32 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
if your calling the double one pictured above stock, your way good. If you have a stock link single tooth replacement (steel gears) your still good.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: B1MAXX] #3173961
09/09/23 09:36 AM
09/09/23 09:36 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I have a few new small block chains. PM me
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Hoop] #3174958
09/13/23 03:15 PM
09/13/23 03:15 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Well, Im going to order me a Edelbrock 7803 - Performer-Link True Roller Timing Chain Set.... So using the Edelbrock Cam & lifter set &
Edelbrock 7803 - Performer-Link True Roller Timing Chain Set should work with my stock rockers ok? https://www.jegs.com/i/Edelbrock/350/7803/10002/-1
https://www.jegs.com/i/Edelbrock/350/2177/10002/-1
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Hoop] #3174962
09/13/23 03:26 PM
09/13/23 03:26 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
That cam is small enough that stock stamped steel rockers should be fine.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Neil] #3174965
09/13/23 03:32 PM
09/13/23 03:32 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Folks would be amazed what stamped steel rockers can handle. When 16 and before the internet was here to tell me how wrong I was the mopar 508/292 with adjustable push rods ran all summer in the local street bracket class. I wondered why it would break up over 7200. whistling
OP.... you must have money to blow because your making something so so simple into something so difficult and costly, but its your money.
$92 for a chain set no better then the $50 BUT it has three keyways which means nothing if your not going to degree it.
Same thing as the edelgobroke but 1/2 the cost.
https://www.ebay.com/itm/386114754231?
Here is the good quality billet thats great for any street/bracket..... SA Billet for same cost as the edlejunk.
https://www.ebay.com/itm/204142235932?
STOP POTATO HATE!
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Hoop] #3174970
09/13/23 03:39 PM
09/13/23 03:39 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Quote
Yes.
Not much else to it, really
shruggy
Rich H.
Esse Quam Videri
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: ZIPPY] #3174976
09/13/23 03:55 PM
09/13/23 03:55 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Ok, thanks, Mine is just mostly a cruiser & do burn outs at car shows, only took it to the strip once, so it seem like this should work for me ok, I only had it over 5000rpm one time for short time & that was by adjusting the kickdown to wear it would kick in above 60!
